Tach is too bright #2836373
10/23/20 07:47 AM
10/23/20 07:47 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I put a new Tach into my 72 Cuda but it is too bright at night. When I turn it down, I can't see my my aftermarket oil/temp gauges or the dash. I put some LED bulbs into the gauges, but when I turn down the light on the tach I can't read those anymore.
I don't really want to put a permanent sun shade type of material on the tach and was thinking about one of those "baby shade" window shades. The kind that you would unfold and put on the window and then take it down when you're done. Trouble is that I don't think that they are made anymore.
Suggestions?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Tach is too bright [Re: cdstl] #2836374
10/23/20 07:58 AM
10/23/20 07:58 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Well, I found my baby shades after all.
BABY SHADE
It may be the least expensive solution.
Re: Tach is too bright [Re: cdstl] #2836385
10/23/20 09:04 AM
10/23/20 09:04 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What color is the tach light? I wonder if a different color would tone it down. You can get colored LEDs or silicone covers to put over a traditional bulb.
Re: Tach is too bright [Re: cdstl] #2836388
10/23/20 09:18 AM
10/23/20 09:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Just put a dab of paint on it.
Coming soon!!!!
Re: Tach is too bright [Re: cdstl] #2836408
10/23/20 10:08 AM
10/23/20 10:08 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Take the bulb out and paint it with candy apple blue or green. Candy colors are translucent and will still let light through but will tone it down and tint it.
Other alternative is crawl junkyards pulling bulbs from 1st generation Grand Cherokees. Some of these have rubber bulb covers in blue.
Re: Tach is too bright [Re: TC@HP2] #2836421
10/23/20 10:57 AM
10/23/20 10:57 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think Summit has them as well...
Coming soon!!!!
Re: Tach is too bright [Re: Mr.Yuck] #2836423
10/23/20 11:01 AM
10/23/20 11:01 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here are some blue ones. I almost bought these for my tach but went with blue LED instead.
https://www.ebay.com/itm/Eagle-Mini-Bulb-Cover-5-pack-BLUE/152462869680?hash=item237f7ec4b0:g:Ww0AAOSwmqZawkP9
Re: Tach is too bright [Re: burdar] #2836426
10/23/20 11:05 AM
10/23/20 11:05 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
If your tach is wired into your dash lights you should be able to dim it
Abe Lincoln
Re: Tach is too bright [Re: dart4forte] #2836447
10/23/20 11:52 AM
10/23/20 11:52 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Read his posts.
Re: Tach is too bright [Re: cdstl] #2836456
10/23/20 12:05 PM
10/23/20 12:05 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I ordered some baby shades and plan on cutting out a disc to slap on when it gets dark. We'll see how it works.
Thanks for the replies.
Re: Tach is too bright [Re: burdar] #2836470
10/23/20 12:32 PM
10/23/20 12:32 PM
moparx Online content
moparx  Online Content
try this for direct link. do not include anything after the "?". up
beer
Re: Tach is too bright [Re: moparx] #2836471
10/23/20 12:34 PM
10/23/20 12:34 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
Thanks, that's been happening a lot lately. I figured there was an easy fix. beer
Re: Tach is too bright [Re: burdar] #2836474
10/23/20 12:45 PM
10/23/20 12:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use a colored sharpie for the bulbs. Works great.
Doug
Re: Tach is too bright [Re: cdstl] #2838273
10/28/20 10:46 AM
10/28/20 10:46 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
FYI
I talked to Autometer about putting a bulb cover on. Evidently this tach, and probably all of them, has "microscopic" bulbs that are soldered into the board. They are not like the incandescent bulbs which we replace with LED bulbs. My option is to buy an aftermarket rheostat dimmer solely for the tach. Not going to happen.
The baby shade film came in and a quick check shows me that it will probably be satisfactory.
Re: Tach is too bright [Re: cdstl] #2838308
10/28/20 12:20 PM
10/28/20 12:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Seems like you could just add a resistor to the wire feeding the light in the tac.
Re: Tach is too bright [Re: fast68plymouth] #2838408
10/28/20 04:20 PM
10/28/20 04:20 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
if the bulb is replaceable put in lower candlepower
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Tach is too bright [Re: cdstl] #2838430
10/28/20 05:05 PM
10/28/20 05:05 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Originally Posted by cdstl
FYI
