Tach is too bright
#2836373
10/23/20 07:47 AM
10/23/20 07:47 AM
Posts: 1,487 STL
cdstl
STL
I put a new Tach into my 72 Cuda but it is too bright at night. When I turn it down, I can't see my my aftermarket oil/temp gauges or the dash. I put some LED bulbs into the gauges, but when I turn down the light on the tach I can't read those anymore.
I don't really want to put a permanent sun shade type of material on the tach and was thinking about one of those "baby shade" window shades. The kind that you would unfold and put on the window and then take it down when you're done. Trouble is that I don't think that they are made anymore.
Suggestions?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Tach is too bright
[Re: cdstl]
#2836374
10/23/20 07:58 AM
10/23/20 07:58 AM
Posts: 1,487 STL
cdstl
STL
Well, I found my baby shades after all. BABY SHADEIt may be the least expensive solution.
[Re: TC@HP2]
#2836421
10/23/20 10:57 AM
10/23/20 10:57 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Take the bulb out and paint it with candy apple blue or green. Candy colors are translucent and will still let light through but will tone it down and tint it.
Other alternative is crawl junkyards pulling bulbs from 1st generation Grand Cherokees. Some of these have rubber bulb covers in blue. I think Summit has them as well...
[Re: burdar]
#2836426
10/23/20 11:05 AM
10/23/20 11:05 AM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
If your tach is wired into your dash lights you should be able to dim it
Abe Lincoln
[Re: cdstl]
#2836456
10/23/20 12:05 PM
10/23/20 12:05 PM
Posts: 1,487 STL
cdstl
STL
I ordered some baby shades and plan on cutting out a disc to slap on when it gets dark. We'll see how it works.
Thanks for the replies.
[Re: cdstl]
#2838273
10/28/20 10:46 AM
10/28/20 10:46 AM
Posts: 1,487 STL
cdstl
STL
FYI
I talked to Autometer about putting a bulb cover on. Evidently this tach, and probably all of them, has "microscopic" bulbs that are soldered into the board. They are not like the incandescent bulbs which we replace with LED bulbs. My option is to buy an aftermarket rheostat dimmer solely for the tach. Not going to happen.
The baby shade film came in and a quick check shows me that it will probably be satisfactory.
[Re: cdstl]
#2838308
10/28/20 12:20 PM
10/28/20 12:20 PM
Posts: 14,497 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Seems like you could just add a resistor to the wire feeding the light in the tac.
[Re: fast68plymouth]
#2838408
10/28/20 04:20 PM
10/28/20 04:20 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
if the bulb is replaceable put in lower candlepower
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: cdstl]
#2838430
10/28/20 05:05 PM
10/28/20 05:05 PM
Posts: 1,487 STL
cdstl
STL
FYI Evidently this tach, and probably all of them, has "microscopic" bulbs that are soldered into the board. They are not like the incandescent bulbs which we replace with LED bulbs.
