Power glide who #2835858
10/21/20 08:51 PM
10/21/20 08:51 PM
nc
E
earthmover Offline OP
E
nc
I'm in need of a trans the 727 just isn't going to make it .
I've talked to dynamic and turbo action
Who do you guys recommend
727 is fine in car until you put the pedal down
So I plan on trans verta shifter shiftnoid and of course driveshaft..
73 tube chassis mild steel
505 inch heads touch up work no big porting big valve
Custom roller 308/328. 645/660
Indy intake 1050 QuickTime carb 1 fogger system
727 8invh turbo action
Ford 9 inch 456 14/32m/t slick
Car is 2700 with driver
If I remember 53% front 46% rear
Or if anybody has 1 forsale
All my 727 stuff is forsale as well
Re: Power glide who [Re: earthmover] #2835879
10/21/20 09:32 PM
10/21/20 09:32 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Lots of good books out there if you want to save some money and build it yourself. I bought three ATI cases and bellhousings for my cars and built a 1.69 low gear for my heads up car, a 1.98 low gear for my small block bracket car, and a 1.80 gear for a spare or green Duster.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Power glide who [Re: pittsburghracer] #2835880
10/21/20 09:34 PM
10/21/20 09:34 PM
PA.
"Little"John
"Little"John
PA.
ATI cases
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Power glide who [Re: pittsburghracer] #2835889
10/21/20 10:16 PM
10/21/20 10:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Weaver's Racing Transmissions. Madison, VA. Does a lot of Top Sportsman, high end stuff. Or he can do a stock case based bracket piece as well.
Transmissions are all he does.
Maybe driving distance for you as well.
Greg Slack is down your way as well for converters.
Both guys are out racing every weekend and don't build cookie cutter units. Everything is done for your app.
Re: Power glide who [Re: earthmover] #2835930
10/22/20 02:12 AM
10/22/20 02:12 AM
FTI in FL. up scope
Good service and great parts bow twocents
Re: Power glide who [Re: Cab_Burge] #2835950
10/22/20 07:11 AM
10/22/20 07:11 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I'd go with either ATI or FTI. I have yet to hear a bad word about FTI.
Re: Power glide who [Re: earthmover] #2836286
10/22/20 09:23 PM
10/22/20 09:23 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Abruzzi
Re: Power glide who [Re: GomangoCuda] #2836336
10/22/20 11:56 PM
10/22/20 11:56 PM
Post falls, Idaho
rgreule Offline
rgreule  Offline
Post falls, Idaho
Hughes, FTI, PTC
Re: Power glide who [Re: rgreule] #2836393
10/23/20 09:26 AM
10/23/20 09:26 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I’ve got a trans specialty in my car works great
Re: Power glide who [Re: scottb] #2836400
10/23/20 09:46 AM
10/23/20 09:46 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I thought COPE was going to start doin those.
Re: Power glide who [Re: scottb] #2836401
10/23/20 09:47 AM
10/23/20 09:47 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
ATI, FTI, Transmission Specialties, BTE, Rossler, are all great places to deal with. I know some trans cases are hard to come by currently, ATI for instance but they are all easy to deal with and make good pieces.
Re: Power glide who [Re: bonefish] #2836920
10/24/20 01:43 PM
10/24/20 01:43 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Now thats FUNNY!
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Power glide who [Re: BANDIT] #2837332
10/25/20 04:15 PM
10/25/20 04:15 PM
E
eh100
eh100
E
You might want to check on what the recertifying process for each tranny and shields is and who can do it.
Time goes by quickly
Re: Power glide who [Re: ] #2849134
11/20/20 03:22 PM
11/20/20 03:22 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
BTE has a nice sale this time of year...20% and they have a pretty good price on a PG as it is.
Re: Power glide who [Re: HardcoreB] #2851068
11/24/20 07:58 PM
11/24/20 07:58 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
ATI Will be pain less
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Power glide who [Re: WHITEDART] #2851117
11/24/20 09:20 PM
11/24/20 09:20 PM
usa,pa
jkwedge540 Offline
jkwedge540  Offline
usa,pa
I thought someone was going to make a SFI case for a 727? What ever happened to that.
Re: Power glide who [Re: jkwedge540] #2851148
11/24/20 10:00 PM
11/24/20 10:00 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
That would by DNJ Components. I go to their Facebook page from time to time and haven't seen any updates in over a yr.
Ok
Re: Power glide who [Re: cudatom] #2851410
11/25/20 02:35 PM
11/25/20 02:35 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
All the big, and some of the small race trans shops offer about the same HP rating trans for near about the same money. What I see that bothers me is the huge spread between what's actually inside. Sometimes really experienced tranny shops know just what it will takes at a min to hold X power. Then there's the quality of X parts at X level. Just saying there can be thousands difference in what's inside 2, X rated transmissions. Be specific about parts used, brands, and just as an example, look at people saying 1.8 straight cut. I see everything from factory parts cut apart with the parts grafted onto them, to full extremely high quality, not one factory part associated. Yet both are found at the same price, one tranny to another.
Lastly, build, or buy for the most power you can imagine having. Doing it every time you improve power is costly.
Re: Power glide who [Re: dthemi] #2851787
11/26/20 12:41 PM
11/26/20 12:41 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Whoever you decide to use, look into the Sonnax line of Powerglide parts.......ESPECIALLY their servo kit.
It is a must as far as Powerglides go to cure their inherent servo pin bias issue.
