Re: Power glide who
[Re: earthmover]
#2835879
10/21/20 09:32 PM
10/21/20 09:32 PM
Posts: 20,143 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lots of good books out there if you want to save some money and build it yourself. I bought three ATI cases and bellhousings for my cars and built a 1.69 low gear for my heads up car, a 1.98 low gear for my small block bracket car, and a 1.80 gear for a spare or green Duster.
Re: Power glide who
[Re: pittsburghracer]
#2835889
10/21/20 10:16 PM
10/21/20 10:16 PM
Posts: 11,479 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Weaver's Racing Transmissions. Madison, VA. Does a lot of Top Sportsman, high end stuff. Or he can do a stock case based bracket piece as well.
Transmissions are all he does.
Maybe driving distance for you as well.
Greg Slack is down your way as well for converters.
Both guys are out racing every weekend and don't build cookie cutter units. Everything is done for your app.
Re: Power glide who
[Re: scottb]
#2836401
10/23/20 09:47 AM
10/23/20 09:47 AM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
ATI, FTI, Transmission Specialties, BTE, Rossler, are all great places to deal with. I know some trans cases are hard to come by currently, ATI for instance but they are all easy to deal with and make good pieces.
Re: Power glide who
[Re: BANDIT]
#2837332
10/25/20 04:15 PM
10/25/20 04:15 PM
eh100
eh100
You might want to check on what the recertifying process for each tranny and shields is and who can do it.
Time goes by quickly
Re: Power glide who
[Re: jkwedge540]
#2851148
11/24/20 10:00 PM
11/24/20 10:00 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
I thought someone was going to make a SFI case for a 727? What ever happened to that. That would by DNJ Components. I go to their Facebook page from time to time and haven't seen any updates in over a yr.
Ok
Re: Power glide who
[Re: cudatom]
#2851410
11/25/20 02:35 PM
11/25/20 02:35 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
All the big, and some of the small race trans shops offer about the same HP rating trans for near about the same money. What I see that bothers me is the huge spread between what's actually inside. Sometimes really experienced tranny shops know just what it will takes at a min to hold X power. Then there's the quality of X parts at X level. Just saying there can be thousands difference in what's inside 2, X rated transmissions. Be specific about parts used, brands, and just as an example, look at people saying 1.8 straight cut. I see everything from factory parts cut apart with the parts grafted onto them, to full extremely high quality, not one factory part associated. Yet both are found at the same price, one tranny to another.
Lastly, build, or buy for the most power you can imagine having. Doing it every time you improve power is costly.
