Re: Real Chrome looking bumper basecoat/ Clearcoat Paint
[Re: R3 Racing]
#2836033
10/22/20 11:27 AM
10/22/20 11:27 AM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Alsa Corp. Mirror Chrome is an awesome product. Have you used it? I saw it on the Google shopping.
[Re: Dragula]
#2836340
10/23/20 12:28 AM
10/23/20 12:28 AM
Posts: 16,495 On the run…
BloFish
On the run…
I have yet to see a quality property that works.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2836387
10/23/20 09:13 AM
10/23/20 09:13 AM
Posts: 4,688 On the parachute mount
n20mstr
I have yet to see a quality property that works. This is definitely something that depends on the person doing it. THE most critical part to getting a good chrome finish is the clear coat. IF you follow the instructions you are applying the chrome to a polished black surface. This is where its tricky. IF that first coat of clear does not dry fast...it wants to "float" the chrome off the black. There is literally no adhesion because you are putting it over a smooth, shiny surface. This is when people get a fuzzy or grey appearance instead of a clean chrome look. Alsa does make a 1K clear that works great for the first coat to lock it down. Just use any regular clear after that. It is a tricky process and each time i do it, they come out a little better...LOL
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2836392
10/23/20 09:24 AM
10/23/20 09:24 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Can you post some pics? Curious of the final appearance. There was a place local to me that could “chrome” Anything. They had a piece of paper chromed in the office. The owner went to the pokie for something and i have no idea where stuff like this can be done now. I did a fiberglass cuda bumper with chrome tape that looked great from 20 ft away.
[Re: TRENDZ]
#2836404
10/23/20 09:59 AM
10/23/20 09:59 AM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Poked around this stuff a couple times. Have seen the product at SEMA and a shop in Vegas. If you can find someone in your area that does it I think it would be your best bet. https://www.cosmichrome.com/https://www.facebook.com/Cosmichrome
[Re: Al_Alguire]
#2836420
10/23/20 10:56 AM
10/23/20 10:56 AM
Posts: 4,689 Wichita
GY3
Wichita
There is a place in Haysville, KS called Alternative Chrome Creations.
He does the spray chrome stuff and it is AMAZING!
Last he told me, though, is he won't do bumpers anymore. Said they turn yellow over time IIRC?
For things like interior plastics it works really well.
[Re: GY3]
#2836489
10/23/20 01:09 PM
10/23/20 01:09 PM
Posts: 1,269 Denver, CO
BigBlockGTS
Denver, CO
Last he told me, though, is he won't do bumpers anymore. Said they turn yellow over time IIRC? Is that because of excessive UV exposure vs. the interior?
[Re: R3 Racing]
#2836670
10/23/20 07:13 PM
10/23/20 07:13 PM
Sammy
Wind Gap,Pa.
I have used it. The surface must be perfect. The chrome goes over black and then a clear goes on top. Were you happy with the end result?
[Re: R3 Racing]
#2837267
10/25/20 01:36 PM
10/25/20 01:36 PM
Sammy
Wind Gap,Pa.
Absolutely satisfied. The stuff is expensive but you will be happy with the end result. I repeat, the surface must be absolutely perfect. Did you spray black 1st before the chrome? The bumper will be perfect. Will sand down and then follow their directions.
[Re: rgreule]
#2837532
10/26/20 12:14 PM
10/26/20 12:14 PM
BloFish
On the run…
Do you happen to have any pictures?
