Stock Oil pump scrol and gear
#2835857
10/21/20 08:50 PM
10/21/20 08:50 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
Does anyone have a stock ( not High Volume) oil pump that they can measure the thickness of the internal parts - scroll and gear height...please
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Stock Oil pump scrol and gear
[Re: rickseeman]
#2836060
10/22/20 12:18 PM
10/22/20 12:18 PM
W.I.N. Racing
Byron, NY
Thank you I was hoping they were .75" as I have a Cast KB pump that I wanted to rebuild. It has stacked gear and scroll. thought they may have just used stock stuff.
[Re: W.I.N. Racing]
#2836131
10/22/20 02:52 PM
10/22/20 02:52 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
My KB is 1.5" but I think everyone wants less volume nowadays. I can't imagine anyone running clearances big enough to use that much oil.
2011 Drag Pak Challenger
[Re: rickseeman]
#2836186
10/22/20 04:56 PM
10/22/20 04:56 PM
W.I.N. Racing
Byron, NY
Yes min is 1.5 as well but when you run 70 wgt and .003 clearances... volume is desired. BTW a cast KB pump flows around 21gal while the new billets flow 30-40gal
