Stock Oil pump scrol and gear #2835857
10/21/20 08:50 PM
10/21/20 08:50 PM
Byron, NY
W.I.N. Racing Offline OP
Byron, NY
Does anyone have a stock ( not High Volume) oil pump that they can measure the thickness of the internal parts - scroll and gear height...please
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Stock Oil pump scrol and gear [Re: W.I.N. Racing] #2835981
10/22/20 09:29 AM
10/22/20 09:29 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
.945
2011 Drag Pak Challenger
Re: Stock Oil pump scrol and gear [Re: rickseeman] #2836060
10/22/20 12:18 PM
10/22/20 12:18 PM
Byron, NY
Byron, NY
Thank you
I was hoping they were .75" as I have a Cast KB pump that I wanted to rebuild. It has stacked gear and scroll. thought they may have just used stock stuff.
'60 Willys CJ5
Re: Stock Oil pump scrol and gear [Re: W.I.N. Racing] #2836131
10/22/20 02:52 PM
10/22/20 02:52 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
My KB is 1.5" but I think everyone wants less volume nowadays. I can't imagine anyone running clearances big enough to use that much oil.
Re: Stock Oil pump scrol and gear [Re: rickseeman] #2836186
10/22/20 04:56 PM
10/22/20 04:56 PM
Byron, NY
Byron, NY
Yes min is 1.5 as well but when you run 70 wgt and .003 clearances... volume is desired. BTW a cast KB pump flows around 21gal while the new billets flow 30-40gal
'60 Willys CJ5
