The elusive unicorn--- Left Threaded Studs. #2834591
10/19/20 12:28 PM
10/19/20 12:28 PM
IMGTX Offline OP
IMGTX  Offline OP
I was swapping rims on my 70 Barracuda and one of the drivers side lugs was snapped off. Probably a casualty of a tire shop that didn't know about the left hand lugs.
I am pretty sure nobody makes the studs anymore but I figured I would ask.
To make it worse this one has a 7-1/4" rear. I know I should convert it to right hand lugs like I did my my convertible but I don't want to.
Anyone make them?
Re: The elusive unicorn--- Left Threaded Studs. [Re: IMGTX] #2834640
10/19/20 01:59 PM
10/19/20 01:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
Measure the O.D. of the knurls and post that on here, I might have some good used ones luck
Re: The elusive unicorn--- Left Threaded Studs. [Re: IMGTX] #2834643
10/19/20 02:01 PM
10/19/20 02:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I see a bunch of threads (no pun intended, but there it is) on LH wheel threads in the Archives.
Short answer: not likely found at the parts store, but resto parts places have them.
Re: The elusive unicorn--- Left Threaded Studs. [Re: Cab_Burge] #2834655
10/19/20 02:38 PM
10/19/20 02:38 PM
IMGTX Offline OP
IMGTX  Offline OP
Thank you, I will do. I don't have any time off until Friday so it may be Saturday.
I have looked through the archives and most of them said nobody made them any more or those supplies have dried up. I will look again.
Thank you for the responses. up
Re: The elusive unicorn--- Left Threaded Studs. [Re: IMGTX] #2834788
10/19/20 09:15 PM
10/19/20 09:15 PM
PM me if you want on here please up
Re: The elusive unicorn--- Left Threaded Studs. [Re: Cab_Burge] #2835009
10/20/20 12:36 PM
10/20/20 12:36 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I thought there was a Moparts member that was the guy for lug nuts/studs.
Also did a lot of container shipping exporting cars.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: The elusive unicorn--- Left Threaded Studs. [Re: hp383] #2835672
10/21/20 02:31 PM
10/21/20 02:31 PM
moparx Offline
moparx  Offline
that was OZHEMI [or something like that]. Jeff was his name.
he hasn't posted in a super long time, but i think he has a fakebook page that is very popular.
beer
Re: The elusive unicorn--- Left Threaded Studs. [Re: Cab_Burge] #2837752
10/26/20 08:46 PM
10/26/20 08:46 PM
IMGTX Offline OP
IMGTX  Offline OP
Here are the dimensions of the broken stud if anyone knows a source.
Re: The elusive unicorn--- Left Threaded Studs. [Re: IMGTX] #2837786
10/26/20 09:58 PM
10/26/20 09:58 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I found LH studs for my '69 Cuda here https://www.hpaulin.com/products/wheel-parts/wheel-studs-bolts
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: The elusive unicorn--- Left Threaded Studs. [Re: RealWing] #2837819
10/27/20 12:08 AM
10/27/20 12:08 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Pretty sure I have a set of serviceable LH studs also. Let me know if if you want me to dig them out.
Re: The elusive unicorn--- Left Threaded Studs. [Re: IMGTX] #2837831
10/27/20 12:46 AM
10/27/20 12:46 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Head markings (if there are any) are useful if you can find an aftermarket parts guy with an interchange manual who is capable of using it.
I used to work for a parts store that had a six foot high, three foot wide shelving unit completely full of obsolete catalogues and interchanges. After the store was sold, the new owner said they didn't need all that antique sh!t cause they were going to computers. When I was there, we only had paper catalogues and wrote invoices by hand. That was 1990. I only found out about it when I stopped in to do some obsolete parts research. It was no surprise to me when the store closed about three years later.
Re: The elusive unicorn--- Left Threaded Studs. [Re: John Brown] #2838114
10/27/20 08:34 PM
10/27/20 08:34 PM
IMGTX Offline OP
IMGTX  Offline OP
I didn't see any head markings unless the concentric rings mean something.
If it were more than one I would just swap to Right Hand studs but since it's just 1 and this car is 90% original I would like to get another lefty.
