440/HEMI 'The Block' by Bulldog Performance. #2834687
10/19/20 03:59 PM
10/19/20 03:59 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
The article on this was first by Muscle Motors, then Read it as being that of Bulldog Performance. Have seen no other info on it. Just wondering what people think, or know someone who got it. Race only, street applications? Worth the money if you want reliable power over 1000+hp?
https://moparconnectionmagazine.com...ance-joins-mopar-connection-for-2019-20/
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: migsBIG] #2834714
10/19/20 05:38 PM
10/19/20 05:38 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Who wrote this: "priority oiling that supplied oil to the main and rod bearings prior to the lifters, ensuring lifter failure won’t happen as a result of total loss of main bearing oil pressure"?
Actually, priority oiling that supplied oil to the main and rod bearings prior to the lifters, ensuring lifter failure WILL happen as a result of total loss of main bearing oil pressure
Using the high school shop class again...
Boffin Emeritus
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: migsBIG] #2834750
10/19/20 07:33 PM
10/19/20 07:33 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I have one it's a 400 block, it's at the machine shop getting the cylinders finished, the pistons are on the brown truck, 55mm cam should be shipped next week. The b1 MC heads are waiting.
So far it looks good, Should have no issue with 1000HP
Joe
Without Data, you’re just another guy with an opinion.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: polyspheric] #2834752
10/19/20 07:35 PM
10/19/20 07:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Total loss of main bearing oil pressure is bad. M'kay?
Story is a year and a half old. Bulldog is a moving target. I don't know the status at this moment. Maybe someone else does. The one I saw at PRI 2 years ago was pretty. And the word was, all the issues were resolved and they'd be cranking them out.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: CMcAllister] #2834782
10/19/20 09:01 PM
10/19/20 09:01 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
A friend bought a 400 B based block for a clients build. He mentioned having to tweak a few things, but the casting looks pretty solid. It's a twin turbo (a pair of 76mm turbos from memory), Trickflow 270 headed deal for a 68-69 Charger. Not sure how they're going with it, the guy that the client got to do all of plumbing, intake and oil pan produced a bunch of grossly overpriced rubbish.
Alan Jones
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: LA360] #2834792
10/19/20 09:22 PM
10/19/20 09:22 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
A friend of mine called me today to come see his new Bulldog Hemi block. I believe that is one of the nicest aftermarket iron blocks I have ever seen! He is going to have it built by a Top local Hemi builder and when he gets it, we will find out how good it is dimensionally, but man, it looks great!
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: Lee446] #2834855
10/20/20 02:42 AM
10/20/20 02:42 AM
I hope to have one of his wedge 4.500 RB blocks home before turkey day, I'll post pictures and my thoughts on what I get it after that shruggy
It's being finish machine at a shop he recommended to use near his shop, bore, deck, lifter bores and main bearing bores luck
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: Cab_Burge] #2835087
10/20/20 02:32 PM
10/20/20 02:32 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I do not believe that the Bulldog and The Block are the same blocks. I have one of the first The Blocks that came from Muscle Motors - came from the first casting run of 10 blocks.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: migsBIG] #2835108
10/20/20 03:24 PM
10/20/20 03:24 PM
PA
RBRE Offline
RBRE  Offline
PA
Over the last 4 years I have purchased 16 Bulldog blocks. Every single block had some kind of issue. They could all be corrected and used if you owned a machine shop except the last 5 we received. Many had the cam tunnel too tight, not an easy fix. All were too tight in the main saddles and needed align hone. Some had the main bearing tangs in the wrong locations. A few blocks wouldn’t accept a distributor because the hole was too small. Three blocks wouldn’t accept the oil drive gear and had to be machined longer for the gear. A recent block had a pin hole in a cylinder. All the blocks have an oil pump bolt that goes into the water jacket. We had 4 blocks that had the soft plug holes machined too small. Some blocks had the rear water holes tapped too big and the plugs would never tighten. All the HEMI blocks need to be machined for pushrod clearance. The oil pickups adaptor was a copy of the world block but is on the wrong angle and the adaptor + pickup hit the crank. Many of the blocks need to be lifter bushed because the lifter holes were .002” tapered. Last week we had a new 540 Hemi on the dyno for cam break in. When we removed the valve covers the oil was milky. Removed the intake and pressurized the tower and found 8 pin holes in the lifter gallery. When I called Bradshaw he said stop leak, should fix it and he would call me in the morning. That is not the answer I want to hear and wouldn’t send it out the door like that. After seeing this new problem we pressure tested the 5 new blocks I have and 4 of them all leak water into the lifter oil passage. There is no fix for this. I have called Bradshaw every day for 10 days and he will not even return my calls. If you have a Bulldog block or waiting for one I would check all the things I mentioned.
Ray Barton
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: RBRE] #2835113
10/20/20 03:30 PM
10/20/20 03:30 PM
Thanks ,Ray for your help on this up
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: RBRE] #2835130
10/20/20 03:53 PM
10/20/20 03:53 PM
AndyF Offline
AndyF  Offline
I have had not done any business with Bradshaw myself but this feedback is consistent with others have said about him and his products for many, many years. There are many threads on Yellow Bullet as well as other forums about Dick Bradshaw. Most of them are from people who were ripped off by him over the past 20 years. If people have been saying for more than 20 years that he ripped them off then that seems like a pattern.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: AndyF] #2835145
10/20/20 04:19 PM
10/20/20 04:19 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m not getting a warm & fuzzy feeling from Rays post.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: fast68plymouth] #2835148
10/20/20 04:26 PM
10/20/20 04:26 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Wow that sounds horrible. Stop leak? Ahhh, hell no.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: INTMD8] #2835167
10/20/20 05:09 PM
10/20/20 05:09 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
WOW! This is why I would not want to be a test mule for a new block. I think I will keep my world block. And check it very thoroughly!
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: fast68plymouth] #2835168
10/20/20 05:10 PM
10/20/20 05:10 PM
AndyF Offline
AndyF  Offline
If Bradshaw isn't going to keep Barton happy then zero chance he'll fix a problem if I buy a block from him. So count me out.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: AndyF] #2835199
10/20/20 06:02 PM
10/20/20 06:02 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
I guess I should count myself fairly lucky with my Bulldog block.
Known issues: ( 1 ) needed to be align honed , this was stated on the paper work with the block, ( 2 ) needed cylinders honed , no big deal
Discovered issues:
( 1 ) one mechanical fuel pump bolt hole not tapped at all.
( 2 ) no clearance machined for mech fuel pump body, more of an annoyance than a problem.
( 3 ) Had to fabricate my own oil pickup adapter because of the problem stated by Barton.
( 4 ) fuel pump pushrod hole too small, had to be reamed to size.
( 5 ) one main bearing tang located wrong.
( 6 ) oil dipstick hole too small, had to be reamed to size.
( 7 ) lifter valley cylinder head studs are a special length, don't ask me how I know,LOL.
( 8 ) rodding from the casting process left in the water jacket, you must look carefully in there and pick it out.
( 9 ) small pit in one cylinder, this was characterized by Nickens Bros. as a sand pit from the casting process. We both agreed that for a street engine it was no big deal.
This block passed a pressure test with flying colors, this should be your first step with any block of unknown quality. Paul
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: iapco103] #2835234
10/20/20 07:21 PM
10/20/20 07:21 PM
AndyF Offline
AndyF  Offline
That seems like too much work for an aftermarket block. The engine shop I work with uses a lot of Dart blocks and typically those get bored, honed, washed and put together. When I bought my Mopar megablock back in 2007 that was all we did. Bore, hone, wash and assembly. Some of the steps you are describing could easily cause an issue with a smaller engine shop. A high end shop might be able to handle those things but not everyone has the tools to fix all that stuff.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: AndyF] #2835399
10/21/20 01:05 AM
10/21/20 01:05 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Thanks for the info. Can't see spending that much money and being told to use block filler to fix problem that shouldn't be there to begin with. Will pass and see what other options come along for blocks.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: migsBIG] #2835442
10/21/20 07:53 AM
10/21/20 07:53 AM
gregsdart Offline
gregsdart  Offline
Give MARSH PERFORMANCE a call. Todd from Marsh has a good reputation on here and knows whats available. I have my name on a new aluminum block that he gas prepaid for. He didn't ask for anything down.
Re: 440/HEMI 'The Block' by Bulldog Performance. [Re: gregsdart] #2835465
10/21/20 09:06 AM
10/21/20 09:06 AM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
How long is the current wait on the BME aluminum block?
