Engine support tool? #2834556
10/19/20 11:19 AM
10/19/20 11:19 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
Hi,
What do you guys recommend to support the engine in the car when you remove the transmission? You can't just let the engine hang without some sort of support. So how do you support the back of the engine with the transmission taken out? I did a search and found nothing.
Re: Engine support tool? [Re: mrob] #2834562
10/19/20 11:25 AM
10/19/20 11:25 AM
an8sec70cuda Offline
I slip a short piece of 1x4 wood b/t the oil pan and drag link.
If you have stock style motor mounts and the exhaust system is still on the car, you don't really need to support it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine support tool? [Re: mrob] #2834573
10/19/20 11:39 AM
10/19/20 11:39 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Something like this works well. https://www.harborfreight.com/autom...b-capacity-engine-support-bar-96524.html
I have seen several home built versions. I have also done the same with a 2x4 and a ratchet strap. But the last time I pulled the trans in my car I simply put a small bottle jack under the right rear corner of the block. Worked great and it was somewhat adjustable from under the car.
Re: Engine support tool? [Re: GomangoCuda] #2834661
10/19/20 02:52 PM
10/19/20 02:52 PM
IMGTX Online content
IMGTX  Online Content
For short term I have used all these options.
For long term I have placed a piece of angle iron across the T bars and put another couple pieces from the rear block bolt holes down to the first piece. MAKE SURE YOU PROTECT THE TORSION BARS. A scratch on the Torsion bars can lead to failure.
I wrap the bar with rubber hose and clamp it with hose clamps. I then use U bolts around the hose to bolt the angle Iron to the Tbars.
A Piece of Angle Iron attached to the tbars also holds up the transmission very nicely when in storage without an engine too.
Re: Engine support tool? [Re: IMGTX] #2834716
10/19/20 05:46 PM
10/19/20 05:46 PM
CA
crackedback Offline
crackedback  Offline
CA
2x4 across engine bay with straps holding back of engine up. Use towels, etc to protect painted surfaces.
Re: Engine support tool? [Re: mrob] #2834728
10/19/20 06:28 PM
10/19/20 06:28 PM
AndyF Offline
AndyF  Offline
I built my own engine support fixture. You can buy or make a fixture without much trouble.
Re: Engine support tool? [Re: AndyF] #2834730
10/19/20 06:39 PM
10/19/20 06:39 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
But the OP wants to know how to hold up the rear of the engine when the transmission is removed shruggy
That fixture looks nice but it would twist and allow the flywheel end to sag work
Re: Engine support tool? [Re: DrCharles] #2834757
10/19/20 07:45 PM
10/19/20 07:45 PM
AndyF Offline
AndyF  Offline
Yes, the person would have to be smart enough to install it on the correct end of the engine.
Re: Engine support tool? [Re: AndyF] #2834763
10/19/20 07:53 PM
10/19/20 07:53 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
My big-block does not have water pump ports on the rear of the engine whistling
Re: Engine support tool? [Re: DrCharles] #2834780
10/19/20 08:59 PM
10/19/20 08:59 PM
AndyF Offline
AndyF  Offline
It wouldn't be a problem for me.
Re: Engine support tool? [Re: AndyF] #2834897
10/20/20 08:38 AM
10/20/20 08:38 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
All of you, thanks for the ideas!
I think I'll try supporting the engine from above like AndyF, crackedback and GoMango suggested.
Re: Engine support tool? [Re: mrob] #2835034
10/20/20 01:21 PM
10/20/20 01:21 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I use a ratchet strap between the torsion bars and a chunk of wood under the oil pan. hammer
Re: Engine support tool? [Re: bobby66] #2835169
10/20/20 05:11 PM
10/20/20 05:11 PM
I like that one. Simple Easy and you can still close the hood. up
Re: Engine support tool? [Re: bobby66] #2835455
10/21/20 08:46 AM
10/21/20 08:46 AM
Maryland
mrob Offline OP
mrob  Offline OP
Maryland
That's a good one, Bobby! Will have to remember it. Good if you need to move the car with the transmission out.
Thanks for responding!
Re: Engine support tool? [Re: mrob] #2835826
10/21/20 08:12 PM
10/21/20 08:12 PM
5thAve Offline
5thAve  Offline
I usually leave the jack or a block of wood under the back of it to hold it up.
