Re: Engine support tool?
[Re: mrob]
#2834562
10/19/20 11:25 AM
10/19/20 11:25 AM
Posts: 13,387 Marion, South Carolina [><]
an8sec70cuda
I slip a short piece of 1x4 wood b/t the oil pan and drag link.
If you have stock style motor mounts and the exhaust system is still on the car, you don't really need to support it.
[Re: GomangoCuda]
#2834661
10/19/20 02:52 PM
10/19/20 02:52 PM
Posts: 12,244 Looking for a way out of Middl...
IMGTX
Something like this works well. https://www.harborfreight.com/autom...b-capacity-engine-support-bar-96524.html I have seen several home built versions. I have also done the same with a 2x4 and a ratchet strap. But the last time I pulled the trans in my car I simply put a small bottle jack under the right rear corner of the block. Worked great and it was somewhat adjustable from under the car. For short term I have used all these options. For long term I have placed a piece of angle iron across the T bars and put another couple pieces from the rear block bolt holes down to the first piece. MAKE SURE YOU PROTECT THE TORSION BARS. A scratch on the Torsion bars can lead to failure. I wrap the bar with rubber hose and clamp it with hose clamps. I then use U bolts around the hose to bolt the angle Iron to the Tbars. A Piece of Angle Iron attached to the tbars also holds up the transmission very nicely when in storage without an engine too.
[Re: AndyF]
#2834730
10/19/20 06:39 PM
10/19/20 06:39 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I built my own engine support fixture. You can buy or make a fixture without much trouble. But the OP wants to know how to hold up the rear of the engine when the transmission is removed That fixture looks nice but it would twist and allow the flywheel end to sag
[Re: DrCharles]
#2834757
10/19/20 07:45 PM
10/19/20 07:45 PM
Posts: 31,075 Oregon
AndyF
I built my own engine support fixture. You can buy or make a fixture without much trouble. But the OP wants to know how to hold up the rear of the engine when the transmission is removed That fixture looks nice but it would twist and allow the flywheel end to sag Yes, the person would have to be smart enough to install it on the correct end of the engine.
[Re: AndyF]
#2834763
10/19/20 07:53 PM
10/19/20 07:53 PM
DrCharles
West Plains, MO
I built my own engine support fixture. You can buy or make a fixture without much trouble. But the OP wants to know how to hold up the rear of the engine when the transmission is removed That fixture looks nice but it would twist and allow the flywheel end to sag Yes, the person would have to be smart enough to install it on the correct end of the engine. My big-block does not have water pump ports on the rear of the engine
[Re: DrCharles]
#2834780
10/19/20 08:59 PM
10/19/20 08:59 PM
AndyF
I built my own engine support fixture. You can buy or make a fixture without much trouble. But the OP wants to know how to hold up the rear of the engine when the transmission is removed That fixture looks nice but it would twist and allow the flywheel end to sag Yes, the person would have to be smart enough to install it on the correct end of the engine. My big-block does not have water pump ports on the rear of the engine It wouldn't be a problem for me.
