Re: Mechanical Roller lifter suggestions.
[Re: Stanton]
#2836602
10/23/20 04:32 PM
10/23/20 04:32 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I have those, I think that the new lifters are 99550's
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: AndyF]
#2836657
10/23/20 06:42 PM
10/23/20 06:42 PM
Posts: 3,371 Md.
carnut68
Md.
If it’s a street/strip build, then I first look at how many miles per year it will get driven...... and then determine if going to a SR makes sense for how the car will be used.
Then, if it looks like the ST is a viable option........along with the particular cam profile, spring loads, and rocker ratio........ determine how good the lifters need to be based on usage, initial cost, and replacement/rebuild time intervals. Low maintenance and pump gas are the main reasons i built another shortblock. Any 511 in an A body will be a handful. If you want low maintenance then go with a hyd roller rather than a solid roller. You'll give up some power above 6000 rpm but you most likely aren't going to take a 511 in an A body to redline very often anyway. I run hyd rollers in both of my cars for the same reason. The way the car is now it never sees the street. Its a 446 race gas only set up 590 cam so its not ideal for street driving. Best et 10.82 best mph 126.0.
America First!
[Re: carnut68]
#2837004
10/24/20 05:47 PM
10/24/20 05:47 PM
Posts: 3,371 Md.
carnut68
Md.
I'm not against solid roller at all. Checking lash is no big deal. I guess a better way to describe it would be turn key, load and go to track.
America First!
[Re: an8sec70cuda]
#2837871
10/27/20 07:52 AM
10/27/20 07:52 AM
Posts: 632 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Isky Red Zone Extreme bushed rollers in mine, .730" net lift, 700lbs open,......lash never changes. Idling at 1100 - 1200 for oil splash. Oil is changed 2x per year, depending on the cars use; clean oil is supposed to be the mail thing to stay on top of with a bushed lifter. I have another near new set of the Isky Red Zones with needle rollers with little dyno use only - I might send them to Isky for conversion, I wonder if there is a contact for this, hmmm. So far, so good I asked them about converting mine from needle bearings to bushings a couple years ago and they said no problem. Costs around $700 IIRC. Thanks Chip, who is the best contact at Isky to contact? Ive done a few thousand kms on mine without issue. The Bullet roller Im using doesnt have super aggressive ramps/lobes', this is the key for a reliable mostly street, some strip mill.
[Re: LAD 524]
#2837873
10/27/20 08:03 AM
10/27/20 08:03 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Isky Red Zone Extreme bushed rollers in mine, .730" net lift, 700lbs open,......lash never changes. Idling at 1100 - 1200 for oil splash. Oil is changed 2x per year, depending on the cars use; clean oil is supposed to be the mail thing to stay on top of with a bushed lifter. I have another near new set of the Isky Red Zones with needle rollers with little dyno use only - I might send them to Isky for conversion, I wonder if there is a contact for this, hmmm. So far, so good I asked them about converting mine from needle bearings to bushings a couple years ago and they said no problem. Costs around $700 IIRC. Thanks Chip, who is the best contact at Isky to contact? Ive done a few thousand kms on mine without issue. The Bullet roller Im using doesnt have super aggressive ramps/lobes', this is the key for a reliable mostly street, some strip mill. I want to say the guy I talked to was Richard? Not sure on that though.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#2837978
10/27/20 01:13 PM
10/27/20 01:13 PM
Posts: 43,748 Bend,OR USA
Cab_Burge
[quote=LAD 524] [quote=an8sec70cuda][quote=LAD 524] I want to say the guy I talked to was Richard? Not sure on that though. Richard Iskenderian is the younger brother of Ron. Richard has managed Isky for a lot of years now, he does good. Not so good results on ordering with Ron
[Re: Cab_Burge]
#2838100
10/27/20 08:00 PM
10/27/20 08:00 PM
Posts: 4,333 Prospect, PA
BSB67
Prospect, PA
[quote=LAD 524] [quote=an8sec70cuda][quote=LAD 524] I want to say the guy I talked to was Richard? Not sure on that though. Richard Iskenderian is the younger brother of Ron. Richard has managed Isky for a lot of years now, he does good. Not so good results on ordering with Ron Same, I think. One good, one not so good.
