Re: 70-71 Cuda rear panel trim, 4-pc
[Re: hemienvy]
#2834074
10/17/20 11:14 PM
10/17/20 11:14 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Same question as many have for repro parts:
Are there any repro sets that actually fit ? If you can find an old discontinued Metro set, they were excellent reproductions, Mike Ross at BEAParts may still have some correct fitting repro corners/outer sections available you'll have to contact him personally to inquire, he may also have some originals pcs/sets?, in regards to some of the current offerings on the market they have a fatal flaw with the corners/outer sections being flared to accept to top/lower strips, however the upper/lower strips are usable.... I've seen a NEW offering on Ebay lately that appear correct in finish.... might want to scope them out? Mike
[Re: fastmark]
#2834130
10/18/20 08:25 AM
10/18/20 08:25 AM
Posts: 21,402 It's a dry heat
gtx6970
It's a dry heat
I used a set of the former metro produced versions. They fit nice. But were a little softer in material then oem. So tended to buldge once pushed over the mounting clip
[Re: gtx6970]
#2834132
10/18/20 08:30 AM
10/18/20 08:30 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
I've found with both the butt trim and the belt moldings on Cudas that the mounting clips make all the difference. Get the ones from Tom at R/T. The only repros that fit right.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Little Detroit]
#2834219
10/18/20 01:46 PM
10/18/20 01:46 PM
Posts: 18,157 Mass
DAYCLONA
Mass
wrong , none of the repro's are correct as seen in the posts above if you notice the top and bottom are absolutely straight and there actually a small degree angle in the center of both pieces approximately 5 % and a small bend on each end of the "c's". and i also sell the repro clips that are actually correct and do fit. The Metro sets I've purchased before they went disco did have the slight V formation for the top and bottom pcs, I'll agree with you on the last few current offerings, the upper and lower pcs are just straight runs...and yes the proper clips make the difference in installation to avoid swells in the moldings, esp the uppers/lowers, I've used NOS clips in the past, as the repro clips offered were too wide/thick to properly fit the profile...I would hope this has been somewhat rectified with the newest offerings coming out of Classic Industries and other vendors....I know the last set I got from YearOne about 2 years ago was the flared end "C" sections... useless IMO Mike
