Has anyone used the Trick Flow damper?
#2832993
10/15/20 12:14 PM
10/15/20 12:14 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I friend offered me his NIB Trick Flow harmonic damper to use on my 543. It's an elastomer damper, not fluid. This one was bought for a n engine he was building for a friend but the man passed before the engine was finished.
I didn't know Trick Flow was in the damper business.
Re: Has anyone used the Trick Flow damper?
[Re: feets]
#2832999
10/15/20 12:27 PM
10/15/20 12:27 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I didn't know Trick Flow was in the damper business. I wouldn’t have a problem at all trying a TrickFlow damper. My son and I both had summit brand dampers spin. Todd from Competition Wedge recommended Powerbold dampers and I tried one with zero issues. ATI is my go to brand for most builds.
[Re: feets]
#2833015
10/15/20 01:00 PM
10/15/20 01:00 PM
Posts: 31,047 Oregon
AndyF
I didn't know Trick Flow was in the damper business. I wouldn't have any problem using it. I'm sure Trick Flow doesn't make the damper, it is most likely the same as the Summit damper which is most likely built by someone who builds dampers for a variety of vendors. Summit owns Trick Flow so there are a lot of parts that those two companies share between themselves. Sometimes they are identical, sometimes the packaging is different.
[Re: AndyF]
#2833025
10/15/20 01:18 PM
10/15/20 01:18 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
After meeting and talking to the owner operator of TrickFlow I have a lot of confidence in their products. If they aren’t satisfied with a product they don’t release it. The small block Mopar intake manifolds were cast last year and they weren’t happy with the quality so to this day the still aren’t released. When they are satisfied they will be.
[Re: feets]
#2833091
10/15/20 04:48 PM
10/15/20 04:48 PM
Posts: 4,209 New York
polyspheric
New York
Question to TF: what engine(s) use this damper?
Boffin Emeritus
[Re: polyspheric]
#2833118
10/15/20 06:46 PM
10/15/20 06:46 PM
feets
Senior Management
Senior Management
Irving, TX
It says the damper fits internally balanced 383 and 440.
