Page 2 of 3 1 2 3
Re: Spoke too soon about MAgnafuel Pumps [Re: A/MP] #2831510
10/11/20 12:43 PM
10/11/20 12:43 PM
Washington
hemienvy Online content
hemienvy  Online Content
Washington
Anyone know which pumps maybe have sealed bearings and aren't so touchy
about running conditions ?
Aeromotive ?
Re: Spoke too soon about MAgnafuel Pumps [Re: hemienvy] #2831619
10/11/20 05:07 PM
10/11/20 05:07 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Aeromotive or Weldon would seem best for constant duty .
I use the Aeromotive A750 , 1st ran for 5 or 7 years daily etc then ate itself up . I have another in it now , i have a spare Holley black cant justify the cost of a spare Aeromotive ,both are set up to interchange. I would not hesitate Weldon plus Weldon are happy to pull dont require mount below fuel level . At least the model i looked at though they say no ethanol . Not a problem for me .
I know a few guys running the A1000 no problems .
The Aeromotive run the motor in the fuel for cooling . But for parts repair must go back to Aeromotive . Thats not so good for me , Weldon you can buy the parts .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Spoke too soon about MAgnafuel Pumps [Re: dart games] #2831653
10/11/20 06:17 PM
10/11/20 06:17 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Originally Posted by 69b1dart
i have a product engineering pump on mine,same as magna flow,same problem,seal went bad up in front of bearing,locked up the bearing,fuel filled the motor,ordered parts from them,he told me magna flow pumps is made in china,but down the road ill be going to a a1000,keep in mine i do run e-85
Been running the A-1000 with e-85 for bout 15 years now no problem so far up
Re: Spoke too soon about MAgnafuel Pumps [Re: racerx] #2831804
10/12/20 08:42 AM
10/12/20 08:42 AM
an8sec70cuda Offline
Sorry to hear this Dragula! That's a tough way to end the season.
FWIW...My Aeromotive A1000 pump has been on my cuda since 2010 and has been flawless.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Spoke too soon about MAgnafuel Pumps [Re: A/MP] #2831807
10/12/20 08:59 AM
10/12/20 08:59 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
MY magnafuel pump armature fell apart in the burnout, 2 seasons old 8 sec car, had a holley black in trailer ran fine!
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Spoke too soon about MAgnafuel Pumps [Re: 440lebaron] #2831813
10/12/20 09:10 AM
10/12/20 09:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Hmmm... conversation makes me think of the Holley Volumax pump on the Duster. Been under there since the late 90’s. No longer available so I’ll be in for a treat when it dies.
Re: Spoke too soon about MAgnafuel Pumps [Re: 440lebaron] #2831814
10/12/20 09:12 AM
10/12/20 09:12 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
About 3 weeks ago, at the bracket finals. My BG 400 fuel pump quit. Seized up, melted relay. Took it apart, lower bearing seized up. Was in the car for 16 years, replaced lower seal 2 years ago. Hour meter on car showed around 345 hours. I replaced it with a Magna Fuel Pro Star 500. I hope that I get as much life out of it, as I did with the BG 400.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Spoke too soon about MAgnafuel Pumps [Re: Dartsport540] #2831827
10/12/20 09:58 AM
10/12/20 09:58 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I run a Product Engineering pump many years never a problem, I sent it back two years ago for a rebuild good people to deal with.... Dartsport540 sorry to see you break the rear at MG hope its not to serious..I was watching on Motormania TV I have a few friends that were there racing.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Spoke too soon about MAgnafuel Pumps [Re: 11secdart] #2831861
10/12/20 11:51 AM
10/12/20 11:51 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I've had a Magnafuel pump now for 17 years. I bought it used, so who knows how old it actually is? Only thing I've had to do with it, was replace a shaft seal. I now carry a spare seal in my trailer.
69 GTX 68 Road Runner
Re: Spoke too soon about MAgnafuel Pumps [Re: JERICOGTX] #2831878
10/12/20 12:25 PM
10/12/20 12:25 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I had the 275 pump and filter combo in the car for 2-3 years and worked well. Was worried we were at the pumps limit and switched to a 500 pump filter combo to allow us to upgrade a few things for more power. Worked all last year, and this year until this past weekend. It was too hot to touch, it was siezed, and probably fried the new relay, and most of all, it let the fuel out, which means it ate the seal, which really concerns me the most. Never had a pump fail and let all the fuel out before. To be fair, I got this pump used from a guy and my 275 I bought new. So I have no idea how old it really is.
I pulled it out of the car yesterday, the filter had some fuel cell shavings in it and some other small crap, probably from when I up-sized the supply hose and fitting and drilled out the fuel cell. The pump I did not pull apart yet. Which way is the best way, take the cover plate off the bottom, or the two long screws that go thru the motor?
I noticed in the diagram posted above it shows to use two relay's, which I did not do. I used a single 30-40 amp one, and the pump is only supposed to draw 12amps, so I figured that should be plenty. It worked this long that way....And mind you, I had to put a pretty good regulator in the car with this unit. It would push right past the old one in the car. I put an Aeromotive Prostock regulator in the car when I upgraded to this big pump.
Re: Spoke too soon about MAgnafuel Pumps [Re: JERICOGTX] #2831883
10/12/20 12:35 PM
10/12/20 12:35 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Fuel pumps can be fickle. I used Holley blue pumps from 1978 to 1994. I could get 1 year out of a new pump, then it would leak out of the vent. I would rebuild them with a Holley service housing for another year. After that, the shaft was done, and into the junk pump pile. I went to the step child BG400, in 1995. It was flawless until 2014. I rebuilt it with a new lower hsg, bearings and seal. It leaked after 1 year. I now have an Aeromotive 11203, to install. Time will tell.
Re: Spoke too soon about MAgnafuel Pumps [Re: Dragula] #2831895
10/12/20 12:48 PM
10/12/20 12:48 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Most Pumps cannot be deadheaded.
Pumps are made to run full speed with a regulator and a large return line back to the tank.
Re: Spoke too soon about MAgnafuel Pumps [Re: Dragula] #2831898
10/12/20 12:54 PM
10/12/20 12:54 PM
Dragula...we run the Aeromotive A2000 pump on the Camaro and it's been great for years. Might consider one of those.
CHIP
Re: Spoke too soon about MAgnafuel Pumps [Re: RATTRAP] #2831906
10/12/20 01:14 PM
10/12/20 01:14 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The pumps mentioned have a built in bypass/return on them.
Re: Spoke too soon about MAgnafuel Pumps [Re: justinp61] #2831938
10/12/20 02:19 PM
10/12/20 02:19 PM
Dragula Offline OP
Dragula  Offline OP
Mine are returned, the regulator is built right into the pump after the filter and then another regulator up front....The old regulator up front would hold the pressure back and had to get switched out.
If I change, I am going back to an Aeromotive pump. I really like them. My preference is towards another A1000 pump......Only 8amp draw carb or efi, and never had a failure like this one.
Re: Spoke too soon about MAgnafuel Pumps [Re: Dragula] #2832074
10/12/20 08:30 PM
10/12/20 08:30 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Another vote for Aeromotive pumps.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Spoke too soon about MAgnafuel Pumps [Re: Dragula] #2832231
10/13/20 10:11 AM
10/13/20 10:11 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
What size line and fitting do you have coming out of that pump? A 500 moves a lot of fuel, and it looks like you may be squeezing into a -8?
What fuel?
Is there any guard to keep it from getting hit with water, rubber, or rocks during a burnout? Looks exposed.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Spoke too soon about MAgnafuel Pumps [Re: A39Coronet] #2832276
10/13/20 12:33 PM
10/13/20 12:33 PM
Dragula Offline OP
Dragula  Offline OP
Pump is installed per their requirements....The infeed line is AN12 I believe. out line should be AN10 and then from the regulator its AN08. Return line is either AN10 or AN-8....
Re: Spoke too soon about MAgnafuel Pumps [Re: Dragula] #2832299
10/13/20 01:40 PM
10/13/20 01:40 PM
moparx Offline
moparx  Offline
i have an aeromotive 340 pump i plan to install in the tank of my charger.
i plan on using the 3/8" line that's there [not much hp] and running a 1/2" return.
electrically, i plan on using heavy gauge wire and a relay, but i don't understand why the magnafuel pump requires a double relay. shruggy
can anyone explain ? TIA.
beer
Re: Spoke too soon about MAgnafuel Pumps [Re: moparx] #2832311
10/13/20 02:02 PM
10/13/20 02:02 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think a lot of people get wrapped up in the bling of all these big fancy pumps. I am fuel injected but my pumps could be used with a carb regulator. I run two Walboro 255LPH pumps, one of them will support 600HP at the tires and I run two for redundancy and to make sure I always have enough fuel(they are staged). They are $120 each. I have had one die on the road but I believe it got trash in it, I live dangerously with no pre filters. I know someone who was running four of them on a 7 second Dart. They are simple, cheap, and reliable.
68 Barracuda Formula S 340
Page 2 of 3 1 2 3
