Re: Proper ways to store an engine that is not being used
[Re: Stanton]
#2831839
10/12/20 10:32 AM
10/12/20 10:32 AM
Posts: 10,757 North Dakota
6PakBee
North Dakota
This is what I am using. I don't know how well it works as I haven't installed the motor yet. Engine Fogging Spray
[Re: 6PakBee]
#2831842
10/12/20 10:59 AM
10/12/20 10:59 AM
Posts: 3,392 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
This is what I am using. I don't know how well it works as I haven't installed the motor yet. Engine Fogging Spray You'll want to fog any bare cast iron or steel for sure. The temperature and humidity swings as the weather changes will cause the cold metal to sweat and condensation to form--this will be one of your biggest issues.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#2831888
10/12/20 12:40 PM
10/12/20 12:40 PM
Posts: 1,565 Macomb, MI
vinnyd76
Macomb, MI
Thank you to everyone for the feedback thus far.
I actually purchased some STA-BIL fogging oil the other day, but wanted to ask the forum for input on proper storage.
[Re: BSB67]
#2831920
10/12/20 01:34 PM
10/12/20 01:34 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
If it's going to be a few months or more, I fog the cylinders (as mentioned) and I loosen the rocker shafts to unload the valves so that the bores are not exposed to the atmosphere. Tape up all orifices and leave yourself a note, attached to the motor, as to what's loose and so on.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: BSB67]
#2831945
10/12/20 02:36 PM
10/12/20 02:36 PM
vinnyd76
Macomb, MI
How long are you storing it? I hate to see a freshly machined and assembled motor just sitting around.
I like the desiccant that John pointed out. Wonder if they make something like that for in the motor, like maybe through the distributor opening. I use DampRid (desiccant) in the engine compartment of my boats when storing for winter. It works.
I think fogging oil is normally used when the motor is running but probably through the plug holes would be good too. .
WD 40 is more like a solvent than a oil. I'd consider something else for longer term storage. Storage timeframe is about 6-months to a year.
[Re: AndyF]
#2832023
10/12/20 05:56 PM
10/12/20 05:56 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
If you are going to store a machined engine for a period of time then it needs to be put in a heated area. If the storage area is unheated then it will rust. This. Been there. Sickening.
