Proper ways to store an engine that is not being used #2831779
10/12/20 06:09 AM
10/12/20 06:09 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Looking for feedback from the forum on the proper way to store (in the mid-west) an engine after complete rebuild. The Mopar engine is rebuilt/reassembled from the intake to the oil pan. There are no exhaust manifolds installed on the engine assembly. The storage facility is insulated, but not continuously heated.
Engine oil is in the motor. Would you manually turn the engine over with a breaker bar by the damper bolt?
Would you spray anything down the spark plug holes (e.g. Sea-Foam, WD-40, etc...)? Spark plugs are loose installed.
Re: Proper ways to store an engine that is not being used [Re: vinnyd76] #2831785
10/12/20 07:14 AM
10/12/20 07:14 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
I would tape off any openings.
Re: Proper ways to store an engine that is not being used [Re: Sniper] #2831806
10/12/20 08:55 AM
10/12/20 08:55 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I spray WD40 into the cylinders every few months when I turn it over. I also prime the motor every now and then. The engine is then wrapped back up in a mattress bag and its tied up to keep dirt and moisture out.
Re: Proper ways to store an engine that is not being used [Re: Stanton] #2831839
10/12/20 10:32 AM
10/12/20 10:32 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is what I am using. I don't know how well it works as I haven't installed the motor yet.
Engine Fogging Spray
Re: Proper ways to store an engine that is not being used [Re: 6PakBee] #2831842
10/12/20 10:59 AM
10/12/20 10:59 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
You'll want to fog any bare cast iron or steel for sure. The temperature and humidity swings as the weather changes will cause the cold metal to sweat and condensation to form--this will be one of your biggest issues.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Proper ways to store an engine that is not being used [Re: wingman] #2831884
10/12/20 12:37 PM
10/12/20 12:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Proper ways to store an engine that is not being used [Re: wingman] #2831888
10/12/20 12:40 PM
10/12/20 12:40 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you to everyone for the feedback thus far.
I actually purchased some STA-BIL fogging oil the other day, but wanted to ask the forum for input on proper storage.
Re: Proper ways to store an engine that is not being used [Re: vinnyd76] #2831909
10/12/20 01:19 PM
10/12/20 01:19 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
How long are you storing it? I hate to see a freshly machined and assembled motor just sitting around.
I like the desiccant that John pointed out. Wonder if they make something like that for in the motor, like maybe through the distributor opening. I use DampRid (desiccant) in the engine compartment of my boats when storing for winter. It works.
I think fogging oil is normally used when the motor is running but probably through the plug holes would be good too. .
WD 40 is more like a solvent than a oil. I'd consider something else for longer term storage.
Re: Proper ways to store an engine that is not being used [Re: BSB67] #2831920
10/12/20 01:34 PM
10/12/20 01:34 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
If it's going to be a few months or more, I fog the cylinders (as mentioned) and I loosen the rocker shafts to unload the valves so that the bores are not exposed to the atmosphere. Tape up all orifices and leave yourself a note, attached to the motor, as to what's loose and so on.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Proper ways to store an engine that is not being used [Re: 5wndwcpe] #2831924
10/12/20 01:58 PM
10/12/20 01:58 PM
fury4speed Offline
fury4speed  Offline
I would also take any pressure off of the valve springs so they are not under load for a long time from sitting
Re: Proper ways to store an engine that is not being used [Re: vinnyd76] #2831934
10/12/20 02:12 PM
10/12/20 02:12 PM
AndyF Offline
AndyF  Offline
If you are going to store a machined engine for a period of time then it needs to be put in a heated area. If the storage area is unheated then it will rust.
Re: Proper ways to store an engine that is not being used [Re: BSB67] #2831945
10/12/20 02:36 PM
10/12/20 02:36 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Storage timeframe is about 6-months to a year.
Re: Proper ways to store an engine that is not being used [Re: vinnyd76] #2831995
10/12/20 04:18 PM
10/12/20 04:18 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Has it been broken in ? I'd prefer that before storing it.
I'd fog the cylinders, pre-oil it, and then from time to time turn it over (breaker bar).
Turning it over will require some pre-oiling though.
A cheap 12V transfer pump that cycles the oil from the pan into an oil pressure port works.
But if it's never been run, I'd worry about the cam/lifter interface, especially if it has stout valve springs.
Re: Proper ways to store an engine that is not being used [Re: AndyF] #2832023
10/12/20 05:56 PM
10/12/20 05:56 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
This. Been there. Sickening.
Re: Proper ways to store an engine that is not being used [Re: vinnyd76] #2832025
10/12/20 05:58 PM
10/12/20 05:58 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Go to Aircraft Spruce web site, they have a pickling oil.
