Re: Spoke too soon about MAgnafuel Pumps
[Re: hemienvy]
#2831619
10/11/20 05:07 PM
10/11/20 05:07 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
Aeromotive or Weldon would seem best for constant duty . I use the Aeromotive A750 , 1st ran for 5 or 7 years daily etc then ate itself up . I have another in it now , i have a spare Holley black cant justify the cost of a spare Aeromotive ,both are set up to interchange. I would not hesitate Weldon plus Weldon are happy to pull dont require mount below fuel level . At least the model i looked at though they say no ethanol . Not a problem for me . I know a few guys running the A1000 no problems . The Aeromotive run the motor in the fuel for cooling . But for parts repair must go back to Aeromotive . Thats not so good for me , Weldon you can buy the parts .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: dart games]
#2831653
10/11/20 06:17 PM
10/11/20 06:17 PM
Posts: 4,069 Mo.
racerx
Mo.
i have a product engineering pump on mine,same as magna flow,same problem,seal went bad up in front of bearing,locked up the bearing,fuel filled the motor,ordered parts from them,he told me magna flow pumps is made in china,but down the road ill be going to a a1000,keep in mine i do run e-85 Been running the A-1000 with e-85 for bout 15 years now no problem so far
[Re: racerx]
#2831804
10/12/20 08:42 AM
10/12/20 08:42 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Sorry to hear this Dragula! That's a tough way to end the season.
FWIW...My Aeromotive A1000 pump has been on my cuda since 2010 and has been flawless.
[Re: A/MP]
#2831807
10/12/20 08:59 AM
10/12/20 08:59 AM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
MY magnafuel pump armature fell apart in the burnout, 2 seasons old 8 sec car, had a holley black in trailer ran fine!
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#2831814
10/12/20 09:12 AM
10/12/20 09:12 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
About 3 weeks ago, at the bracket finals. My BG 400 fuel pump quit. Seized up, melted relay. Took it apart, lower bearing seized up. Was in the car for 16 years, replaced lower seal 2 years ago. Hour meter on car showed around 345 hours. I replaced it with a Magna Fuel Pro Star 500. I hope that I get as much life out of it, as I did with the BG 400.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#2831827
10/12/20 09:58 AM
10/12/20 09:58 AM
Posts: 4,977 new jersey usa
11secdart
new jersey usa
I run a Product Engineering pump many years never a problem, I sent it back two years ago for a rebuild good people to deal with.... Dartsport540 sorry to see you break the rear at MG hope its not to serious..I was watching on Motormania TV I have a few friends that were there racing.
[Re: 11secdart]
#2831861
10/12/20 11:51 AM
10/12/20 11:51 AM
Posts: 10,022 MN
JERICOGTX
MN
I've had a Magnafuel pump now for 17 years. I bought it used, so who knows how old it actually is? Only thing I've had to do with it, was replace a shaft seal. I now carry a spare seal in my trailer.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2831878
10/12/20 12:25 PM
10/12/20 12:25 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
I had the 275 pump and filter combo in the car for 2-3 years and worked well. Was worried we were at the pumps limit and switched to a 500 pump filter combo to allow us to upgrade a few things for more power. Worked all last year, and this year until this past weekend. It was too hot to touch, it was siezed, and probably fried the new relay, and most of all, it let the fuel out, which means it ate the seal, which really concerns me the most. Never had a pump fail and let all the fuel out before. To be fair, I got this pump used from a guy and my 275 I bought new. So I have no idea how old it really is.
I pulled it out of the car yesterday, the filter had some fuel cell shavings in it and some other small crap, probably from when I up-sized the supply hose and fitting and drilled out the fuel cell. The pump I did not pull apart yet. Which way is the best way, take the cover plate off the bottom, or the two long screws that go thru the motor?
I noticed in the diagram posted above it shows to use two relay's, which I did not do. I used a single 30-40 amp one, and the pump is only supposed to draw 12amps, so I figured that should be plenty. It worked this long that way....And mind you, I had to put a pretty good regulator in the car with this unit. It would push right past the old one in the car. I put an Aeromotive Prostock regulator in the car when I upgraded to this big pump.
[Re: JERICOGTX]
#2831883
10/12/20 12:35 PM
10/12/20 12:35 PM
Posts: 5,989 Anoka County, MN
Leigh
Anoka County, MN
Fuel pumps can be fickle. I used Holley blue pumps from 1978 to 1994. I could get 1 year out of a new pump, then it would leak out of the vent. I would rebuild them with a Holley service housing for another year. After that, the shaft was done, and into the junk pump pile. I went to the step child BG400, in 1995. It was flawless until 2014. I rebuilt it with a new lower hsg, bearings and seal. It leaked after 1 year. I now have an Aeromotive 11203, to install. Time will tell.
[Re: Dragula]
#2831895
10/12/20 12:48 PM
10/12/20 12:48 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
I noticed in the diagram posted above it shows to use two relay's, which I did not do. I used a single 30-40 amp one, and the pump is only supposed to draw 12amps, so I figured that should be plenty. It worked this long that way....And mind you, I had to put a pretty good regulator in the car with this unit. It would push right past the old one in the car. I put an Aeromotive Prostock regulator in the car when I upgraded to this big pump. Most Pumps cannot be deadheaded. Pumps are made to run full speed with a regulator and a large return line back to the tank.
[Re: Dragula]
#2831898
10/12/20 12:54 PM
10/12/20 12:54 PM
an8sec70cuda
Dragula...we run the Aeromotive A2000 pump on the Camaro and it's been great for years. Might consider one of those.
[Re: RATTRAP]
#2831906
10/12/20 01:14 PM
10/12/20 01:14 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I noticed in the diagram posted above it shows to use two relay's, which I did not do. I used a single 30-40 amp one, and the pump is only supposed to draw 12amps, so I figured that should be plenty. It worked this long that way....And mind you, I had to put a pretty good regulator in the car with this unit. It would push right past the old one in the car. I put an Aeromotive Prostock regulator in the car when I upgraded to this big pump. Most Pumps cannot be deadheaded. Pumps are made to run full speed with a regulator and a large return line back to the tank. The pumps mentioned have a built in bypass/return on them.
[Re: justinp61]
#2831938
10/12/20 02:19 PM
10/12/20 02:19 PM
Dragula
Mine are returned, the regulator is built right into the pump after the filter and then another regulator up front....The old regulator up front would hold the pressure back and had to get switched out. Dragula...we run the Aeromotive A2000 pump on the Camaro and it's been great for years. Might consider one of those. If I change, I am going back to an Aeromotive pump. I really like them. My preference is towards another A1000 pump......Only 8amp draw carb or efi, and never had a failure like this one.
[Re: Dragula]
#2832074
10/12/20 08:30 PM
10/12/20 08:30 PM
Posts: 16,479 On the run…
BloFish
On the run…
Another vote for Aeromotive pumps.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Dragula]
#2832231
10/13/20 10:11 AM
10/13/20 10:11 AM
Posts: 1,111 Usa
A39Coronet
Usa
What size line and fitting do you have coming out of that pump? A 500 moves a lot of fuel, and it looks like you may be squeezing into a -8?
What fuel?
Is there any guard to keep it from getting hit with water, rubber, or rocks during a burnout? Looks exposed.
[Re: Dragula]
#2832299
10/13/20 01:40 PM
10/13/20 01:40 PM
Posts: 19,402 north of coder
moparx
i have an aeromotive 340 pump i plan to install in the tank of my charger. i plan on using the 3/8" line that's there [not much hp] and running a 1/2" return. electrically, i plan on using heavy gauge wire and a relay, but i don't understand why the magnafuel pump requires a double relay. can anyone explain ? TIA.
[Re: moparx]
#2832311
10/13/20 02:02 PM
10/13/20 02:02 PM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
I think a lot of people get wrapped up in the bling of all these big fancy pumps. I am fuel injected but my pumps could be used with a carb regulator. I run two Walboro 255LPH pumps, one of them will support 600HP at the tires and I run two for redundancy and to make sure I always have enough fuel(they are staged). They are $120 each. I have had one die on the road but I believe it got trash in it, I live dangerously with no pre filters. I know someone who was running four of them on a 7 second Dart. They are simple, cheap, and reliable.
68 Barracuda Formula S 340
