Re: 2002 Minivan brakes dragging
[Re: stumpy]
#2830996
10/10/20 12:24 AM
10/10/20 12:24 AM
Posts: 949 Klamath Falls, Oregon
Dartslantsix
after driving open the bleeders one at a time and see if they squirt fluid. If it just leaks some then its not the master hanging up. If it squirts a stream then its.holding pressure some where. This makes sense. I'll try it tomorrow. If it squirts- it could be MC or hoses or something with ABS maybe?
[Re: Dartslantsix]
#2831001
10/10/20 01:28 AM
10/10/20 01:28 AM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
Collapsed brake hose x100: Done a few on my Rams and a set on the '04 Neon, AND a set on one of the '71 Challengers; seems to be a common problem on Dodge products. Have to thank the Moparts Member that diagnosed the issue. Killed the battery in my temp gun on these damn Mopars checking rotor temps!
Mo' Farts
Moderated by "tbagger".
[Re: Dartslantsix]
#2831034
10/10/20 08:41 AM
10/10/20 08:41 AM
Posts: 12,293 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It is most likely the calipers. But frankly, it doesn't matter whether it is the calipers or the hoses. Go ahead and change them all while you are at it. It is no more work to change hoses and calipers than it is to change either one alone. And if you shop it out, none of it is very expensive. We have changed a lot of the calipers that were stuck and a few hoses that were collapsed, but have never seen a master cylinder that was holding the front brakes on.
It is common enough, that I go to a pick-a-part yard and look for a van with re-manned calipers and new hoses. Usually $30+/- will buy it all. That generation of van used 2 different calipers; one for rear drum and one for rear disc. They are easy to tell apart.
Master, again and still
[Re: 1969ronnie]
#2831438
10/11/20 09:38 AM
10/11/20 09:38 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Well, I guess that's possible and the owner's manual says to change it regularly. But I have to say, that of all the stuff we work on, I have personally NEVER seen an instance where not changing the brake fluid has caused a problem. Never.
Just one example; our shop has an '02 Town and Country van with 245k miles that we still use for towing cars and hauling parts home from St. Louis. Most of the brake fluid in it is original. Some got changed when we replaced the front calipers, but most is original. No problems so far. That is only one example of hundreds of vehicles we have worked on that still had the original brake fluid. And many, like the Town and Country, had ABS too.
So, while it may be a good idea to replace the brake fluid, for the vast majority of vehicles, it is a waste of time and money. Now, flushing the cooling system and putting in fresh anti-freeze is something that absolutely should be done regularly. But most people don't and we see the consequences of that all the time.
