2002 Minivan brakes dragging #2830968
10/09/20 10:13 PM
10/09/20 10:13 PM
Klamath Falls, Oregon
Dartslantsix Offline OP
First, the van: 2002 Chrysler Voyager short wheel base 3.3L, disc/drum.
It appears the brakes are dragging. Both fronts are hot to the touch after driving. Hot enough that you can't even touch the lugnuts.
Last spring I changed the pads and cleaned/greased the pins, so I think it might be an master cylinder issue.
How should I go about diagnosing this?
Thanks.
Re: 2002 Minivan brakes dragging [Re: Dartslantsix] #2830980
10/09/20 10:58 PM
10/09/20 10:58 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
after driving open the bleeders one at a time and see if they squirt fluid. If it just leaks some then its not the master hanging up. If it squirts a stream then its.holding pressure some where. Could be the master or could be something downstream from there. Be sure you aren't accidently dragging the brakes.
Re: 2002 Minivan brakes dragging [Re: stumpy] #2830991
10/09/20 11:37 PM
10/09/20 11:37 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
brake hoses also
Re: 2002 Minivan brakes dragging [Re: stumpy] #2830996
10/10/20 12:24 AM
10/10/20 12:24 AM
Quote
This makes sense. I'll try it tomorrow. If it squirts- it could be MC or hoses or something with ABS maybe?
Re: 2002 Minivan brakes dragging [Re: Dartslantsix] #2831001
10/10/20 01:28 AM
10/10/20 01:28 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Collapsed brake hose x100:
Done a few on my Rams and a set on the '04 Neon, AND a set on one of the '71 Challengers; seems to be a common problem on Dodge products. down Have to thank the Moparts Member that diagnosed the issue.
Killed the battery in my temp gun on these damn Mopars checking rotor temps!
Mo' Farts
Moderated by "tbagger".
Re: 2002 Minivan brakes dragging [Re: Dartslantsix] #2831034
10/10/20 08:41 AM
10/10/20 08:41 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
It is most likely the calipers. But frankly, it doesn't matter whether it is the calipers or the hoses. Go ahead and change them all while you are at it. It is no more work to change hoses and calipers than it is to change either one alone. And if you shop it out, none of it is very expensive. We have changed a lot of the calipers that were stuck and a few hoses that were collapsed, but have never seen a master cylinder that was holding the front brakes on.
It is common enough, that I go to a pick-a-part yard and look for a van with re-manned calipers and new hoses. Usually $30+/- will buy it all. That generation of van used 2 different calipers; one for rear drum and one for rear disc. They are easy to tell apart.
Master, again and still
Re: 2002 Minivan brakes dragging [Re: DaveRS23] #2831045
10/10/20 09:14 AM
10/10/20 09:14 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Happened to both of my 06 Chrysler minivans, both times it was, the calipers, they are well known for issues. Could be other problems like mentioned above but if you google it you will find mostly caliper issues. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: 2002 Minivan brakes dragging [Re: Rhinodart] #2831358
10/10/20 10:12 PM
10/10/20 10:12 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Hi Dart , what color is the brake fluid ? clear , coffee milk , dark coffee , or GOD FORBID , BLACK COFFEE ? drive ronnie brake fluid flushing and changing is pretty important on newer stuff , especially with ABS . HUGE bills if you don't !
Re: 2002 Minivan brakes dragging [Re: 1969ronnie] #2831438
10/11/20 09:38 AM
10/11/20 09:38 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Well, I guess that's possible and the owner's manual says to change it regularly. But I have to say, that of all the stuff we work on, I have personally NEVER seen an instance where not changing the brake fluid has caused a problem. Never.
Just one example; our shop has an '02 Town and Country van with 245k miles that we still use for towing cars and hauling parts home from St. Louis. Most of the brake fluid in it is original. Some got changed when we replaced the front calipers, but most is original. No problems so far. That is only one example of hundreds of vehicles we have worked on that still had the original brake fluid. And many, like the Town and Country, had ABS too.
So, while it may be a good idea to replace the brake fluid, for the vast majority of vehicles, it is a waste of time and money. Now, flushing the cooling system and putting in fresh anti-freeze is something that absolutely should be done regularly. But most people don't and we see the consequences of that all the time.
Re: 2002 Minivan brakes dragging [Re: DaveRS23] #2831685
10/11/20 07:51 PM
10/11/20 07:51 PM
Okay, I got out there today and cracked the bleeder screw and the fluid just dribbled out. So we're going to replace the calipers.
Thanks for help on the diagnosis.
-Dave
