power brake to manual master cyl for b body #2830095
10/07/20 07:54 PM
10/07/20 07:54 PM
tampa florida
1badrt Offline OP
1badrt  Offline OP
tampa florida
Hello all, am converting my beep beep to manual disc, how do you convert from booster to manual mater cyl at fire wall, mounting holes different location than power. manual brake and steering nut here
70 beep beep 383 N96 4spd 68 beep beep, eddy headed 383 4 spd 73 340 chally 73 340 duster
Re: power brake to manual master cyl for b body [Re: 1badrt] #2830143
10/07/20 08:52 PM
10/07/20 08:52 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
It takes a different firewall reinforcing plate for a manual. Is yours a Bendix or midland ross booster?
Re: power brake to manual master cyl for b body [Re: fastmark] #2830244
10/08/20 09:35 AM
10/08/20 09:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Not just the plate but also a master pusrod for manual brakes.Then get a master for say a 70 C body with discs.They work great as thats all we use on conversions.IIRC the pedal holes should be the same.Rocky
Chrysler Firepower
Re: power brake to manual master cyl for b body [Re: therocks] #2830378
10/08/20 01:50 PM
10/08/20 01:50 PM
moparx Offline
moparx  Offline
i have always thought the pedal ratio for the manual brake master had the attachment hole closer to the pivot so as to give a more advantageous ratio needed for the manual brake master ? shruggy
beer
Re: power brake to manual master cyl for b body [Re: moparx] #2830487
10/08/20 05:45 PM
10/08/20 05:45 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The manual brakes cly connects straight to the pedal. The powers uses the lever system under the dash.
Re: power brake to manual master cyl for b body [Re: moparx] #2830642
10/09/20 06:40 AM
10/09/20 06:40 AM
VA
dragon slayer Offline
VA
beer
Me too.
Looking at the parts books, looks like C bodies did, but early through 69 B used the same pedal. Now the 70 parts book does show a new pedal for B body Power Brakes Auto but used the same pedal for either brake system with Man trans, and the Man brake Auto trans same as earlier pedal.
Re: power brake to manual master cyl for b body [Re: dragon slayer] #2830656
10/09/20 08:07 AM
10/09/20 08:07 AM
Andrewh Offline
Andrewh  Offline
But you need to check the pedal.
There are two holes sometimes and you have to change it to the other hole when switching between power and manual.
Re: power brake to manual master cyl for b body [Re: Andrewh] #2830666
10/09/20 08:43 AM
10/09/20 08:43 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Instead of swapping the firewall plates you can buy an adapter from Mancini or Andy F. (I think) which fits between the plate and mc and converts from 4 bolts to two. Also, a late model aluminum Mopar mc with a 1-1/32 bore is ideal for this swap.
Re: power brake to manual master cyl for b body [Re: Stanton] #2832464
10/13/20 08:58 PM
10/13/20 08:58 PM
GA
roadrunninMark Offline
GA
You can get the kit from Dr. Diff, highly recommend his products. I've gone manual disc from manual drum on my RR. I got his 15/16" alum. master cyl.
