oil accumulator install #2828904
10/05/20 12:22 PM
10/05/20 12:22 PM
lansing mi.
e85mope Offline OP
e85mope  Offline OP
lansing mi.
I would like to see where everyone that runs a oil accumulator installs the feed line at on a big block. Any pics would be greatly appreciated. Thanks.
Re: oil accumulator install [Re: e85mope] #2828915
10/05/20 12:44 PM
10/05/20 12:44 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I just run an oil filter bypass sandwiched between the pump and filter. Have done that on several engines and have that on my Hemi now. The accumulator gets used more as a pre-luber than anything else anymore.
Here's a pic of it on during mock-up:
Master, again and still
Re: oil accumulator install [Re: e85mope] #2828932
10/05/20 01:14 PM
10/05/20 01:14 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We used a Milodon billet oil pump with the 2 -10 fittings. We plumbed that to a external filter mount, and then "Teed" off the motor feed side with the accumulator.
Re: oil accumulator install [Re: e85mope] #2828940
10/05/20 01:33 PM
10/05/20 01:33 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I'm also using the sandwich adapter.
Re: oil accumulator install [Re: e85mope] #2828944
10/05/20 01:45 PM
10/05/20 01:45 PM
AndyF Offline
AndyF  Offline
I use one of the ports at the back of the block above the bellhousing.
Re: oil accumulator install [Re: AndyF] #2828949
10/05/20 02:07 PM
10/05/20 02:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Indy Max pump has two fittings. Mine has the pick up in one, accumulator in the other.
Doug
Re: oil accumulator install [Re: dvw] #2828969
10/05/20 03:31 PM
10/05/20 03:31 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
T it where the oil pump goes. What I’m doing on 340, doing away with the filter.
Re: oil accumulator install [Re: e85mope] #2828999
10/05/20 05:00 PM
10/05/20 05:00 PM
I have never used the new 3 quart one I bought yet, I will install it into a #12 AN Tee on the return line going to the block, not the pump side tsk, from the remote (#12AN) oil filter line up
I did install one on a customers 426 street hemi motor years ago by drilling the rear of the stock drivers side oil passover passage a little bigger( from 1/16 or maybe 1/8 NPT) to maybe 1/4 NPT wrench
But looking back now I think it should be used on the front of the motor to feed oil into the motor from a bigger line like when being run , not from the back through a very small hole tsk work shruggy
I think it needs to supplement the oil supply when needed if the pressure drops enough to allow it to work, not fight the oil pressure coming in from the front of the motor from the oil pump when the pressure drops a little work I hope this thinking make sense luck
Re: oil accumulator install [Re: Cab_Burge] #2829440
10/06/20 05:58 PM
10/06/20 05:58 PM
moparx Offline
moparx  Offline
has anyone done an accusump install that was "hidden" from the engine bay ?
i'm thinking of something like this for the new engine in my charger.
i'm looking to "hide" as much as possible, the underhood clutter.
beer
Re: oil accumulator install [Re: moparx] #2829533
10/06/20 08:38 PM
10/06/20 08:38 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I wouldn’t call it hiding, but mine was mounted between the two seats behind the shifter. Manual ball valve for priming etc...
There was enough weight out front.
Track techs didn’t like it, but nothing(at that time) in the rules saying no. Don’t know about today’s rules.
Re: oil accumulator install [Re: moparx] #2829544
10/06/20 08:58 PM
10/06/20 08:58 PM
AndyF Offline
AndyF  Offline
Depends if you have to pass tech and which tech. Road race tech allows the oil tank in the passenger compartment but NHRA doesn't. For road race cars we used to put the accumulator on the roll cage behind the driver. For drag cars we put it in the trunk between the wheel wells.
Re: oil accumulator install [Re: AndyF] #2829601
10/07/20 12:42 AM
10/07/20 12:42 AM
fredericksburg,va
fredericksburg,va
That seems like a lot of line and slow response time back to engine. Ok for a pre Oiler I guess
Re: oil accumulator install [Re: cudaman1969] #2829622
10/07/20 03:28 AM
10/07/20 03:28 AM
MD
HEMI472 Offline
HEMI472  Offline
MD
why do you need one ?????
Re: oil accumulator install [Re: cudaman1969] #2829625
10/07/20 05:10 AM
10/07/20 05:10 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I don’t see what would make you think this. The oil line is not empty.
Re: oil accumulator install [Re: moparx] #2829626
10/07/20 05:45 AM
10/07/20 05:45 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We mounted ours under the radiator, 3 qt Canton. You can barely see it. We got one as added insurance, the car is a wheelstander and has a shallow sump for ground clearance.
Re: oil accumulator install [Re: Tig] #2829664
10/07/20 09:21 AM
10/07/20 09:21 AM
London, England
Gavin Offline
Gavin  Offline
London, England
I thought about mounting mine inside the front fender, I think it would fit on the Challenger, YMMV.......
Re: oil accumulator install [Re: HEMI472] #2829809
10/07/20 01:29 PM
10/07/20 01:29 PM
moparx Offline
moparx  Offline
i would like one because when done, my car most likely will not be started every other day, and i don't like a dry start. also, i don't want to have to pull the distributor all the time to spin the oil pump over for a pre-lube.
as i stated before, i want a clean under hood look.
i don't want it in the passenger compartment for several reasons, although mounting it underneath the floor or under the trunk floor with a remote switching device/valve might deserve serious consideration. thanks for that idea whomever suggested that ! up
beer
Re: oil accumulator install [Re: moparx] #2830133
10/07/20 08:33 PM
10/07/20 08:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Not a big block , but here is where my 3 qt. Moroso sits on an early A body.
Hood closes with no issues , and it is hilarious to hear people point at it and tell their buddies that it is a " Nitrous system " at cruise nights.
I have told people what it is when they ask , but correcting people just doesn't go well some times so I allow them their illusions.
Yeah............three times and counting.
Re: oil accumulator install [Re: tubtar] #2830203
10/08/20 05:02 AM
10/08/20 05:02 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I hear you on that, the Canton ones are blue as well grin
