Stabil what one? #2828403
10/03/20 07:50 PM
10/03/20 07:50 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
I want "Storage' but also want "Protection" since it has a Metal Tank so need 360. And here in La, we have to have 10% Ethanol in all our gas!
Should I get the Stabil Marine 360 that is Blue? Or use the Yellow 360 that says use now and also add Red to store? As in use both I assume they can be mixed? I have Red already but would like the stuff that is for Alky and Tanks as well?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Stabil what one? [Re: 340SIX] #2828422
10/03/20 08:42 PM
10/03/20 08:42 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
First recommendation is don't store it with any fuel with any ethanol in it. You should be able to find "recreational" fuel somewhere - it's got zero ethanol. Here's a link for the listings for stations in Louisiana - hopefully something near you: https://www.pure-gas.org/index.jsp?stateprov=LA
Re: Stabil what one? [Re: Sunroofcuda] #2828441
10/03/20 09:38 PM
10/03/20 09:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
There's a Lucas additive for ethanol that I use for my generator & mower, that's also for storage (stabilizer). Zero problems.
I've been using the red Stabil for years in the cars & truck that sit during the winter, they have regular pump 10% ethanol fuel in them, zero issues.
Re: Stabil what one? [Re: Sunroofcuda] #2828443
10/03/20 09:44 PM
10/03/20 09:44 PM
BlueRacer69 Offline
BlueRacer69  Offline
I agree with sunroofcuda. Try to find some rec. gas. ( recreational fuel ).
Re: Stabil what one? [Re: BlueRacer69] #2828453
10/03/20 10:08 PM
10/03/20 10:08 PM
340SIX Offline OP
340SIX  Offline OP
I keep 3 barrels at hurricane time and then use it in the cars to use it up. 100% gas is 2 to 3 times as much $.
Re: Stabil what one? [Re: 340SIX] #2828469
10/03/20 11:00 PM
10/03/20 11:00 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
ALL my stuff gets premium pump fuel(e10) and Seafoam. 1 oz/gal. Been doing that for years with zero fuel issues. I don't drain anything. Hell, I ran my weed wacker(Ryobi) half the summer on last years fuel. All my 50:1 2 stroke stuff is mixed out of the same fuel. Chain saw, weed wacker, leaf blower...2 stroke. Tractor, snow blower, pressure washer, log splitter all 4 stroke. Zero issues!!
Re: Stabil what one? [Re: 340SIX] #2828497
10/04/20 04:34 AM
10/04/20 04:34 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
What are you storing or I should ask how much fuel does the tank hold? Did I miss what you are storing if so sorry. Reason I'm asking is if it is only a few gallons just go to any lawn and garden center and buy a couple of quarts or gallons of canned non-ethanol 92/93 octane gasoline and any Stabil, Seafoam, etc., and mix accordingly. There's True Fuel, VP, and even Stihl Motomix 2-stroke premix non-ethanol at 93 octane, good for a year opened and 3 year shelf life not opened. You should also be able to find non-ethanol marine fuel near any water or marina if you need a larger quantity.
Re: Stabil what one? [Re: A12] #2828503
10/04/20 07:02 AM
10/04/20 07:02 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I used to put the red Stabil in my snowblower until it gummed up the carb (Stabil has a shelf life). I now run recreation fuel in it. No issues since then as far as running. I use Startron to store stuff instead of Stabil now. I used to add Seafoam for storage, but now just add a bit in the small engines to run them dry, add fuel and put them in the shed. I add a tad of Startron to the jug I use for recreation fuel as a stabilizer. I would recommend Startron if using fuel with ethanol and second choice would be Seafoam. No experience with Stabil 360 or marine version.
Re: Stabil what one? [Re: 340SIX] #2828556
10/04/20 11:01 AM
10/04/20 11:01 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Not in Tulsa Oklahoma.
Easy to find and and if I remember correctly about the same price as E10 91 octane.
Re: Stabil what one? [Re: Dcuda69] #2828656
10/04/20 06:01 PM
10/04/20 06:01 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted by Dcuda69
................ I don't drain anything. Hell, I ran my weed wacker(Ryobi) half the summer on last years fuel. All my 50:1 2 stroke stuff is mixed out of the same fuel. Chain saw, weed wacker, leaf blower...2 stroke. Tractor, snow blower, pressure washer, log splitter all 4 stroke. Zero issues!!
Same, plus two mowers, two leaf blowers, two outboard motors, and an inboard. I use regular gas for most everything, and I don't add anything. I couldn't imagine even keeping track of what's got what and when. Hell, I've got 12 fuel cans.
Pulled my 68 GTS out in June. It sat since November 2015. No fuel additives when it went into storage. It started right and ran fine.
Re: Stabil what one? [Re: BSB67] #2828729
10/04/20 09:47 PM
10/04/20 09:47 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I've had the RoadRunner stored for over 2 years twice and used the red Stabil with no issues. They have a new one for Ethanol, haven't tried it yet.
