Re: Exhaust Manifold Coating
[Re: 70HemiGTX]
#2829520
10/06/20 08:15 PM
10/06/20 08:15 PM
Posts: 1,637 Florida
GMP440
Nice Article on Slip Plate. I think that may be the route I will take. I appreciate all the comments and other questions you guys posted. The more info the better informed decision you can make. Thanks guys and keep the questions and comments coming. You have some good options; cast blast paint or Slip Plate. Both will give you good results. Using and applying slip plate to the manifolds is just a different way of coating your manifolds. It's kind of like that "Paint Job on a Budget " thread . The one about using Rustoleum paint to paint a car with. That one took off like wild fire.
[Re: 440_Offroader]
#2840062
11/01/20 10:44 AM
11/01/20 10:44 AM
GMP440
Would the Slip Pate work on headers as well or is it intended more for the cast iron manifolds that are more porous? Anyone tried This? It works well on cast iron because of the pores, etc. Might not stay on the headers because they have a smooth surface. I would give it a try. See how it works and let us know.
[Re: GMP440]
#2840909
11/02/20 07:56 PM
11/02/20 07:56 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Would the Slip Pate work on headers as well or is it intended more for the cast iron manifolds that are more porous? Anyone tried This? It works well on cast iron because of the pores, etc. Might not stay on the headers because they have a smooth surface. I would give it a try. See how it works and let us know. My take as well.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: vinnyd76]
#3071766
08/27/22 08:42 AM
08/27/22 08:42 AM
Posts: 1,385 Az
69hemibeep
Az
Ive had them done for 2 customers and no complaints. The shop I use has a light and dark cast color in high heat powder coat I like the light one myself.
1969 Hemi Roadrunner 2nd owner
[Re: 69hemibeep]
#3072736
08/30/22 06:21 PM
08/30/22 06:21 PM
Posts: 28,616 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Ive had them done for 2 customers and no complaints. The shop I use has a light and dark cast color in high heat powder coat I like the light one myself. what temp is the powder coat good too? We used to get ceramic coated here within driving distance but the closed up. We do have quite a few shows that do Powder Coat here but did not think it would be high temp enough
[Re: 340SIX]
#3073631
09/02/22 05:22 PM
09/02/22 05:22 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Ive had them done for 2 customers and no complaints. The shop I use has a light and dark cast color in high heat powder coat I like the light one myself. what temp is the powder coat good too? We used to get ceramic coated here within driving distance but the closed up. We do have quite a few shows that do Powder Coat here but did not think it would be high temp enough Standard HI TEMP POWDER coatings are good up to 600 degrees MAX short term, some of the newer SILICONE POWDER coating can sustain up to 1000 degree F MAX for short periods.....cast iron manifolds will see easily upwards of 800 degrees for prolonged periods....so as I mentioned in the other thread, powder coating exhaust manifolds is great for wall art or trailer queens, otherwise ceramic coating from the likes of Jet Hot or Rocket Coatings are the way to go, not that expensive either, and you can get the inside done as well, and it will last....probably longer than one's ownership of the vehicle
