Re: Exhaust Manifold Coating [Re: GMP440] #2829402
10/06/20 04:18 PM
10/06/20 04:18 PM
PA
70HemiGTX Offline OP
PA
Originally Posted by GMP440
Nice Article on Slip Plate. I think that may be the route I will take. I appreciate all the comments and other questions you guys posted. The more info the better informed decision you can make. Thanks guys and keep the questions and comments coming.
Re: Exhaust Manifold Coating [Re: 70HemiGTX] #2829520
10/06/20 07:15 PM
10/06/20 07:15 PM
GMP440 Offline
GMP440  Offline
You have some good options; cast blast paint or Slip Plate. Both will give you good results. Using and applying slip plate to the manifolds is just a different way of coating your manifolds.
It's kind of like that "Paint Job on a Budget " thread . The one about using Rustoleum paint to paint a car with. That one took off like wild fire.
Re: Exhaust Manifold Coating [Re: GMP440] #2831279
10/10/20 05:35 PM
10/10/20 05:35 PM
People's Republic of Kali
70runner Offline
70runner  Offline
I've done the Eastwood stainless hi temp on older 70RR resto (2011) and Slip Plate on 69 Charger resto (2018). Eastwood is showing some aging - discoloration and such. Slip Plate remains perfect and IMO provides slightly darker, more realistic look.
Re: Exhaust Manifold Coating [Re: 70runner] #2833834
10/17/20 11:11 AM
10/17/20 11:11 AM
Alberta
440_Offroader Offline
Alberta
Would the Slip Pate work on headers as well or is it intended more for the cast iron manifolds that are more porous? Anyone tried This?
Re: Exhaust Manifold Coating [Re: 440_Offroader] #2840062
11/01/20 09:44 AM
11/01/20 09:44 AM
GMP440 Offline
GMP440  Offline
It works well on cast iron because of the pores, etc. Might not stay on the headers because they have a smooth surface. I would give it a try. See how it works and let us know.
Re: Exhaust Manifold Coating [Re: GMP440] #2840909
11/02/20 06:56 PM
11/02/20 06:56 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
My take as well.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Exhaust Manifold Coating [Re: topside] #3071714
08/26/22 08:28 PM
08/26/22 08:28 PM
Macomb, MI
V
vinnyd76 Offline
vinnyd76  Offline
V
Macomb, MI
Researching all options... anyone have experience with powder coating exhaust manifolds?
Re: Exhaust Manifold Coating [Re: vinnyd76] #3071766
08/27/22 07:42 AM
08/27/22 07:42 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Ive had them done for 2 customers and no complaints. The shop I use has a light and dark cast color in high heat powder coat I like the light one myself.
1969 Hemi Roadrunner 2nd owner
Re: Exhaust Manifold Coating [Re: 69hemibeep] #3072736
08/30/22 05:21 PM
08/30/22 05:21 PM
Shopping @ HoBo Fright
340SIX Offline
340SIX  Offline
what temp is the powder coat good too?
We used to get ceramic coated here within driving distance but the closed up. We do have quite a few shows that do Powder Coat here but did not think it would be high temp enough
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Exhaust Manifold Coating [Re: 340SIX] #3073631
09/02/22 04:22 PM
09/02/22 04:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Standard HI TEMP POWDER coatings are good up to 600 degrees MAX short term, some of the newer SILICONE POWDER coating can sustain up to 1000 degree F MAX for short periods.....cast iron manifolds will see easily upwards of 800 degrees for prolonged periods....so as I mentioned in the other thread, powder coating exhaust manifolds is great for wall art or trailer queens, otherwise ceramic coating from the likes of Jet Hot or Rocket Coatings are the way to go, not that expensive either, and you can get the inside done as well, and it will last....probably longer than one's ownership of the vehicle
