Wrecked in my own driveway #2827914
10/02/20 02:30 PM
10/02/20 02:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Stuck throttle stuck on a dry hop test.I had no return spring on the carbs as I do any other time.
Re: Wrecked in my own driveway [Re: Clanton] #2827917
10/02/20 02:32 PM
10/02/20 02:32 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
That is my hitch from my truck that was parked there
Re: Wrecked in my own driveway [Re: Clanton] #2827919
10/02/20 02:35 PM
10/02/20 02:35 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Oh $#!+ frown
Rich H.
Esse Quam Videri
Re: Wrecked in my own driveway [Re: Clanton] #2827921
10/02/20 02:39 PM
10/02/20 02:39 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
You need a longer driveway for those kind of shenanigans
Rich H.
Esse Quam Videri
Re: Wrecked in my own driveway [Re: ZIPPY] #2827923
10/02/20 02:46 PM
10/02/20 02:46 PM
moparx Offline
moparx  Offline
main thing is, you are ok, right ? [other than needing a change of underpants]
the car can be fixed.
do you have a cable or solid rod for throttle control ?
sorry to see extra work now needed after you have worked so hard !
beer
Re: Wrecked in my own driveway [Re: moparx] #2827928
10/02/20 02:50 PM
10/02/20 02:50 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Yikes !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Wrecked in my own driveway [Re: moparx] #2827930
10/02/20 02:54 PM
10/02/20 02:54 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am fine,I had 35ft to stop with the front brakes locked.I have a lokar cable.the rear fender is the only bad part folding up from the hitch,The other stuff will push out from the fence post.My own fault I was going to move the truck in the drive.
Re: Wrecked in my own driveway [Re: bigdad] #2827934
10/02/20 02:59 PM
10/02/20 02:59 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
[quote=bigdad]Yikes !
Today I was topping off the trans fluid after fixing a trans line leak.The smoke in the video is from fresh painted headers that you posted.
Re: Wrecked in my own driveway [Re: Clanton] #2827943
10/02/20 03:21 PM
10/02/20 03:21 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Some minor bends,dents
Re: Wrecked in my own driveway [Re: Clanton] #2827946
10/02/20 03:25 PM
10/02/20 03:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Crap!! Sorry to see that. Another sad lesson learned the hard way. Looks like the damage isn't awful bad. How's the front end look?
Re: Wrecked in my own driveway [Re: stumpy] #2827948
10/02/20 03:34 PM
10/02/20 03:34 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got Very lucky on the front
Re: Wrecked in my own driveway [Re: Clanton] #2827963
10/02/20 04:29 PM
10/02/20 04:29 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Dang. Glad it's not real bad
Re: Wrecked in my own driveway [Re: FastmOp] #2828011
10/02/20 06:00 PM
10/02/20 06:00 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Bummer.
69 GTX 68 Road Runner
Re: Wrecked in my own driveway [Re: FastmOp] #2828012
10/02/20 06:01 PM
10/02/20 06:01 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Yeah, what he said.
Re: Wrecked in my own driveway [Re: Clanton] #2828028
10/02/20 06:42 PM
10/02/20 06:42 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Damn glad it wasn't worst. Similar stuff happened to a couple of my brothers. Both times it took out part of my dads garage.
Ok
Re: Wrecked in my own driveway [Re: cudatom] #2828033
10/02/20 07:07 PM
10/02/20 07:07 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Scary [censored] there, I've had a motor mount break and lock the throttle @ WFO, and it wasn't a blown motor. Sucks to damage your toy, but it doesn't look too bad. The little things can really mess you up. Best of luck getting it fixed up sawzall
Re: Wrecked in my own driveway [Re: Skeptic] #2828035
10/02/20 07:16 PM
10/02/20 07:16 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank for the well wishes!I am going to pull the valve covers and check the rockers with it being on the 7k chip for 4 seconds.I have good push rods and HS rockers and will check the rocker studs also.The rear qtr is going to need replaced but I have all Winter to think about that.I will put the return spring on .
Thanks again!
Re: Wrecked in my own driveway [Re: Clanton] #2828049
10/02/20 07:50 PM
10/02/20 07:50 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Thanks again!
dentless paint remover will take that out for $150.00.thats not too too bad.
Re: Wrecked in my own driveway [Re: Clanton] #2828052
10/02/20 07:56 PM
10/02/20 07:56 PM
Superfreak
Superfreak
You sounded a little winded.
Re: Wrecked in my own driveway [Re: ] #2828054
10/02/20 08:08 PM
10/02/20 08:08 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Dang.
just Dang.
I can just about guess when the S.O.B. 'ing started.
Glad it wasn't worse.
