DRIVING IT TO THE TRACK #2827567
10/01/20 08:16 PM
10/01/20 08:16 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Anyone have a reasonable combo for a drive to the track, race and drive back? Was at the track on Sunday talking to and getting beat by factory cars running high 10's low 11's. I'd prefer to keep it as old school as possible Thanks
Re: DRIVING IT TO THE TRACK [Re: A/MP] #2827593
10/01/20 08:57 PM
10/01/20 08:57 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
We do exactly that with a 505" RB, a mild .545 hydraulic roller cam, 2800 (rated) 11" stall and 3.54 rear gear. Low, low 11's n/a with an intake that fits under a flat hood. Low 10's with a shot of spray.
It feels like a regular 440 with a small cam until you hit the loud pedal!
Re: DRIVING IT TO THE TRACK [Re: A/MP] #2827596
10/01/20 09:07 PM
10/01/20 09:07 PM
AndyF Offline
AndyF  Offline
The bigger the engine the easier it is to build something that you can drive easily yet still run in the 10's. A pump gas 540 with 3.54 gears can drive pretty nice yet run hard at the track. Especially if you are smart about taking some weight out in the right spots.
Re: DRIVING IT TO THE TRACK [Re: A/MP] #2827600
10/01/20 09:12 PM
10/01/20 09:12 PM
I can give you my old pump gas combination that ran a bunch of 10.00 in my Duster that weighed 3450 lb. with me in it with the air cleaner on through the 3.0 inch exhaust with Magnaflow 7x14 inch oval muffs with 3.0 inch inlet on the sides with center exit mounted at the rear bumper.
It was a 1976 400 block stroke to 4.300 with a 4.375 bore, 6.800 long CAT BB Chevy type rods, Ross dished pistons that had 10.78 to 1 compression with Indy SR max wedge heads with 76.00 CC chambers. That combination had a Indy 400-3 intake with several different Holley 1050 CFM Dominator carbs. on it that I tested. The best power it made that way was 727 HP on Oregon 92 octane non ethanol pump swill devil
I had the motor moved back right at one inch based on the trans cross member using a set of elephant ears on the front with a stock type trans mount elongated on the rear to allow me to slide it, the motor and trans, back one inch wrenchdevil
That car had ladder bars with coil overs for the rear suspension with a set of double adjustable Strange 15 inch extended coil overs, narrowed Dana 60 with a spool,35 spline axles and 4.10 stock Dana gears.
Stock 1971 Duster front suspension with six cylinder torsion bars and a set of Koni SPA1 front shocks.
That car would hook up in a mud puddle during a rainstorm boogie whistling AKA aside it worked real well on M/T ET street bias ply tires on the street as well good on M/T ET Street Drag Radials on a good track, 1.42 best 60 Ft ,I think work CRS disease whiney
The ET Street Radials didn't work good at all on the street or on a marginal track down whiney shruggy
I put around 3500 miles on that car on the street and hundreds of passes on it at different tracks before trading it off towards my current S/P car, it was a lot of fun and exceeded all of my expectations up boogie
IHTHs luck
Re: DRIVING IT TO THE TRACK [Re: AndyF] #2827618
10/01/20 09:29 PM
10/01/20 09:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
512", Indy EZ1s & intake w/850DP, 3000 stall 727 & 3.55s with 28" tire, '72 Duster w/'glass hood, pump 93 = 11.30s through full exhaust.
Don't recall the cam specs off the top of my head, but it wasn't a big stick.
Nothing trick, just SS springs, 3/8" fuel line, mech pump, big alum radiator.
Big motor, reasonable gear, 6000 RPM limit, 3000-3500 weight is a decent recipe.
Re: DRIVING IT TO THE TRACK [Re: topside] #2827623
10/01/20 09:42 PM
10/01/20 09:42 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
My A body( all steel) runs that on pump gas with a bone stock 360 bottom end through the muffs, and i weigh over 300 driving it..lol
Shift it at 6100, ( around 10 to 1 compression, maybe)
Big blocks..lol
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: DRIVING IT TO THE TRACK [Re: B3422W5] #2827632
10/01/20 10:13 PM
10/01/20 10:13 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
You could always cheat a little.... Nice light A-body with a modern power plant! No emissions stuff needed and probably almost 1000lbs lighter.
https://www.racingjunk.com/Modern-H...W-.html?category_id=5641&np_offset=0
Re: DRIVING IT TO THE TRACK [Re: Dragula] #2827694
10/02/20 05:33 AM
10/02/20 05:33 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
RB440 , 0.520 lift solid flat tappet , TF270 heads , street exhaust , 4.1 gears , 6000vert ,30" radial slick 3690lbs 10.70 best.
Source cnc heads same 440 bottom end , 5000vert , 28" radial slick , 10.88 best
Both pump gas , drive 40 miles to track , fit rear tyres , empty boot , fit airplate/screen
Both were shifted @ 6000
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: DRIVING IT TO THE TRACK [Re: tex013] #2827702
10/02/20 06:23 AM
10/02/20 06:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Just take a look at dragweek combos.... Moparbilly’s ride was a great example of a 10 sec street driver
Re: DRIVING IT TO THE TRACK [Re: J_BODY] #2827725
10/02/20 08:23 AM
10/02/20 08:23 AM
UK
rb446 Offline
rb446  Offline
UK
Well I guess not many if at all are going to build something like we have but here it is>
589ci wedge, 10:1cr, 572-13 365cnc heads, 1.55 jesels, small Herbert s/roller, .625/.625..260-270@.050, indy 440-2, small 950HP, spray bar oiling, 2.1/8>2.1/4" TTI's, 4.10 Dana, 10x29's@16psi, 4200 stall with a low 1st gear 727 in a 3800@line '69RR., mono's/caltracs/9-ways/90-10's, run on V-power pump.
Drive to track, Race, drive home all with full exhausts to rear, mechanical water pump, + drive to shows, car has been 10.35@128, been 130+...1.43 60's best.....no issues at all...relying on the big torque to get it moving, HP nothing to write about, shift@5800, trap@6200>6300. Next year will see it with a Thumper 1050 Dominator and possibly run with open hdrs?......hoping for high 10.1's>2's. up
][Linked Image]
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: DRIVING IT TO THE TRACK [Re: A/MP] #2827746
10/02/20 09:04 AM
10/02/20 09:04 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've driven my Dart to the track a bunch, it gets driven to work and out for ice cream on cruise nights. It's a pump 93 434" small block, Indy heads, solid roller, 727, the converter flashes 5600 and 4.10 gears. The car never gets hot, doesn't foul plugs and unlike me isn't cantankerous at all. It runs mid 6.20's at 110 in the 1/8 at 3350#.
Who needs a big block, pffft stirthepot laugh2
Re: DRIVING IT TO THE TRACK [Re: J_BODY] #2827800
10/02/20 11:05 AM
10/02/20 11:05 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Great recommendation to look at the combos these folks use.
You can drive to the track even if it is two hundred miles!
Re: DRIVING IT TO THE TRACK [Re: 340Cuda] #2827802
10/02/20 11:10 AM
10/02/20 11:10 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Dizuster's car comes to mind.
Boost is your friend.
Kevin
Re: DRIVING IT TO THE TRACK [Re: justinp61] #2827808
10/02/20 11:19 AM
10/02/20 11:19 AM
UK
rb446 Offline
rb446  Offline
UK
At 3350 we'd be along side you in the traps smile...personally I'd prefer what you have but not in a B-bod.
Re: DRIVING IT TO THE TRACK [Re: Twostick] #2827809
10/02/20 11:20 AM
10/02/20 11:20 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Other than the debate between a SS/BB, my thoughts are getting the duration, stall and rear gear to work to make it quick and also manageable for the ride to and from. What should I be looking for?
Re: DRIVING IT TO THE TRACK [Re: A/MP] #2827812
10/02/20 11:23 AM
10/02/20 11:23 AM
UK
rb446 Offline
rb446  Offline
UK
Exactly what we have up cool...last forever @those rpm's.
Re: DRIVING IT TO THE TRACK [Re: A/MP] #2827814
10/02/20 11:24 AM
10/02/20 11:24 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I drive my 67 Barracuda to the track often, race, then drive home. Only once did that bite me in the butt...5 years ago, third round of a race it kicked a rod out the side just before the finish line. Had to call the wife to come get me, grab the truck and trailer, scoop up my pile and take it home.
That said, I have also won quite a few races on days when I drove it in. Here is the combo:
67 Barracuda, 3250 lbs
408 stroker, ported Edelbrocks, Hughes solid FT cam (264/268 @ 0.05), Howards EMD lifters
Victor intake, 13:1 compression, home build 750dp e85 carb (running e85 obviously),
727, 8" PTC converter, Caltracs (mono's, links, shocks), MO875 with spool and 4.10 gears, Hoosier 275/60/r15 drag radials
All this through 3" Dynomax race bullets.
Car runs 1.38 60', 6.44@105.9mph, 10.19@130.5mph.
Running on e85 means I can drive it anytime during the summer and not worry about it getting too hot....heck, most races I never use my fan, lol.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: DRIVING IT TO THE TRACK [Re: FlyFish] #2827847
10/02/20 12:11 PM
10/02/20 12:11 PM
Portage,michigan
Portage,michigan
Extremely impressive!!
1.41 best 60 foot
6.60 at 103.90 1/8
Re: DRIVING IT TO THE TRACK [Re: A/MP] #2827855
10/02/20 12:36 PM
10/02/20 12:36 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I drive my Charger everywhere, 10k miles on the drivetrain, with one engine freshen up after a flat cam issue at 5k miles, the track is about 140 miles round trip depending on road closures, it now has a 4.10 gear but have not made it to the track yet, but with a 3.54 gear has been 11.04 @ 123, 1700ft DA, 4100lb , cold AC, overdrive trans, full exhaust to the bumper, 512 lowdeck,9.7to1,, small hydro roller cam, 440 source Heads, I hope to crack the 10's with the 4.10 gear.
Re: DRIVING IT TO THE TRACK [Re: A/MP] #2827856
10/02/20 12:37 PM
10/02/20 12:37 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Our old 528 combo did real well running a best of 10.006 @ 137 @ 3850lb. about 15 years ago. It was a 4.50 bore 4.15 stroke combo. Good heads (572-13) and 440-3x and a 1250 (ish) Pro Systems Dom. Solid Roller, Lift was around .720" IIRC. 4:10 gears. Drove it all over, work, shows and just for fun. Originally it ran 10.7's, It was really scienced out by the end, the converter / cam choice was the biggest gains followed by the manifold and carb. HTH's up
