Re: DRIVING IT TO THE TRACK
[Re: A/MP]
#2827593
10/01/20 08:57 PM
10/01/20 08:57 PM
Posts: 4,704 Wichita
GY3
Wichita
Anyone have a reasonable combo for a drive to the track, race and drive back? Was at the track on Sunday talking to and getting beat by factory cars running high 10's low 11's. I'd prefer to keep it as old school as possible Thanks We do exactly that with a 505" RB, a mild .545 hydraulic roller cam, 2800 (rated) 11" stall and 3.54 rear gear. Low, low 11's n/a with an intake that fits under a flat hood. Low 10's with a shot of spray. It feels like a regular 440 with a small cam until you hit the loud pedal!
[Re: A/MP]
#2827600
10/01/20 09:12 PM
10/01/20 09:12 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Anyone have a reasonable combo for a drive to the track, race and drive back? Was at the track on Sunday talking to and getting beat by factory cars running high 10's low 11's. I'd prefer to keep it as old school as possible Thanks I can give you my old pump gas combination that ran a bunch of 10.00 in my Duster that weighed 3450 lb. with me in it with the air cleaner on through the 3.0 inch exhaust with Magnaflow 7x14 inch oval muffs with 3.0 inch inlet on the sides with center exit mounted at the rear bumper. It was a 1976 400 block stroke to 4.300 with a 4.375 bore, 6.800 long CAT BB Chevy type rods, Ross dished pistons that had 10.78 to 1 compression with Indy SR max wedge heads with 76.00 CC chambers. That combination had a Indy 400-3 intake with several different Holley 1050 CFM Dominator carbs. on it that I tested. The best power it made that way was 727 HP on Oregon 92 octane non ethanol pump swill I had the motor moved back right at one inch based on the trans cross member using a set of elephant ears on the front with a stock type trans mount elongated on the rear to allow me to slide it, the motor and trans, back one inch That car had ladder bars with coil overs for the rear suspension with a set of double adjustable Strange 15 inch extended coil overs, narrowed Dana 60 with a spool,35 spline axles and 4.10 stock Dana gears. Stock 1971 Duster front suspension with six cylinder torsion bars and a set of Koni SPA1 front shocks. That car would hook up in a mud puddle during a rainstorm AKA aside it worked real well on M/T ET street bias ply tires on the street as well good on M/T ET Street Drag Radials on a good track, 1.42 best 60 Ft ,I think CRS disease The ET Street Radials didn't work good at all on the street or on a marginal track I put around 3500 miles on that car on the street and hundreds of passes on it at different tracks before trading it off towards my current S/P car, it was a lot of fun and exceeded all of my expectations IHTHs
[Re: AndyF]
#2827618
10/01/20 09:29 PM
10/01/20 09:29 PM
Posts: 20,926 A collage of whims
topside
A collage of whims
512", Indy EZ1s & intake w/850DP, 3000 stall 727 & 3.55s with 28" tire, '72 Duster w/'glass hood, pump 93 = 11.30s through full exhaust. Don't recall the cam specs off the top of my head, but it wasn't a big stick. Nothing trick, just SS springs, 3/8" fuel line, mech pump, big alum radiator.
Big motor, reasonable gear, 6000 RPM limit, 3000-3500 weight is a decent recipe.
[Re: topside]
#2827623
10/01/20 09:42 PM
10/01/20 09:42 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Big motor, reasonable gear, 6000 RPM limit, 3000-3500 weight is a decent recipe. My A body( all steel) runs that on pump gas with a bone stock 360 bottom end through the muffs, and i weigh over 300 driving it..lol Shift it at 6100, ( around 10 to 1 compression, maybe) Big blocks..lol
[Re: Dragula]
#2827694
10/02/20 05:33 AM
10/02/20 05:33 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
RB440 , 0.520 lift solid flat tappet , TF270 heads , street exhaust , 4.1 gears , 6000vert ,30" radial slick 3690lbs 10.70 best. Source cnc heads same 440 bottom end , 5000vert , 28" radial slick , 10.88 best Both pump gas , drive 40 miles to track , fit rear tyres , empty boot , fit airplate/screen Both were shifted @ 6000
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: J_BODY]
#2827725
10/02/20 08:23 AM
10/02/20 08:23 AM
Posts: 570 UK
rb446
UK
Well I guess not many if at all are going to build something like we have but here it is> 589ci wedge, 10:1cr, 572-13 365cnc heads, 1.55 jesels, small Herbert s/roller, .625/.625..260-270@.050, indy 440-2, small 950HP, spray bar oiling, 2.1/8>2.1/4" TTI's, 4.10 Dana, 10x29's@16psi, 4200 stall with a low 1st gear 727 in a 3800@line '69RR., mono's/caltracs/9-ways/90-10's, run on V-power pump. Drive to track, Race, drive home all with full exhausts to rear, mechanical water pump, + drive to shows, car has been 10.35@128, been 130+...1.43 60's best.....no issues at all...relying on the big torque to get it moving, HP nothing to write about, shift@5800, trap@6200>6300. Next year will see it with a Thumper 1050 Dominator and possibly run with open hdrs?......hoping for high 10.1's>2's. ]
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: J_BODY]
#2827800
10/02/20 11:05 AM
10/02/20 11:05 AM
Posts: 3,527 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Just take a look at dragweek combos.... Moparbilly’s ride was a great example of a 10 sec street driver Great recommendation to look at the combos these folks use. You can drive to the track even if it is two hundred miles!
[Re: justinp61]
#2827808
10/02/20 11:19 AM
10/02/20 11:19 AM
Posts: 570 UK
rb446
UK
I've driven my Dart to the track a bunch, it gets driven to work and out for ice cream on cruise nights. It's a pump 93 434" small block, Indy heads, solid roller, 727, the converter flashes 5600 and 4.10 gears. The car never gets hot, doesn't foul plugs and unlike me isn't cantankerous at all. It runs mid 6.20's at 110 in the 1/8 at 3350#. Who needs a big block, pffft At 3350 we'd be along side you in the traps ...personally I'd prefer what you have but not in a B-bod.
[Re: A/MP]
#2827812
10/02/20 11:23 AM
10/02/20 11:23 AM
Posts: 570 UK
rb446
UK
Exactly what we have ...last forever @those rpm's.
[Re: A/MP]
#2827814
10/02/20 11:24 AM
10/02/20 11:24 AM
Posts: 1,178 Indy
FlyFish
Indy
I drive my 67 Barracuda to the track often, race, then drive home. Only once did that bite me in the butt...5 years ago, third round of a race it kicked a rod out the side just before the finish line. Had to call the wife to come get me, grab the truck and trailer, scoop up my pile and take it home.
That said, I have also won quite a few races on days when I drove it in. Here is the combo:
67 Barracuda, 3250 lbs 408 stroker, ported Edelbrocks, Hughes solid FT cam (264/268 @ 0.05), Howards EMD lifters Victor intake, 13:1 compression, home build 750dp e85 carb (running e85 obviously), 727, 8" PTC converter, Caltracs (mono's, links, shocks), MO875 with spool and 4.10 gears, Hoosier 275/60/r15 drag radials All this through 3" Dynomax race bullets.
Car runs 1.38 60', 6.44@105.9mph, 10.19@130.5mph.
Running on e85 means I can drive it anytime during the summer and not worry about it getting too hot....heck, most races I never use my fan, lol.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#2827847
10/02/20 12:11 PM
10/02/20 12:11 PM
B3422W5
Portage,michigan
Running on e85 means I can drive it anytime during the summer and not worry about it getting too hot....heck, most races I never use my fan, lol. Extremely impressive!!
[Re: A/MP]
#2827855
10/02/20 12:36 PM
10/02/20 12:36 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I drive my Charger everywhere, 10k miles on the drivetrain, with one engine freshen up after a flat cam issue at 5k miles, the track is about 140 miles round trip depending on road closures, it now has a 4.10 gear but have not made it to the track yet, but with a 3.54 gear has been 11.04 @ 123, 1700ft DA, 4100lb , cold AC, overdrive trans, full exhaust to the bumper, 512 lowdeck,9.7to1,, small hydro roller cam, 440 source Heads, I hope to crack the 10's with the 4.10 gear.
[Re: A/MP]
#2827856
10/02/20 12:37 PM
10/02/20 12:37 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Anyone have a reasonable combo for a drive to the track, race and drive back? Was at the track on Sunday talking to and getting beat by factory cars running high 10's low 11's. I'd prefer to keep it as old school as possible Thanks Our old 528 combo did real well running a best of 10.006 @ 137 @ 3850lb. about 15 years ago. It was a 4.50 bore 4.15 stroke combo. Good heads (572-13) and 440-3x and a 1250 (ish) Pro Systems Dom. Solid Roller, Lift was around .720" IIRC. 4:10 gears. Drove it all over, work, shows and just for fun. Originally it ran 10.7's, It was really scienced out by the end, the converter / cam choice was the biggest gains followed by the manifold and carb. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
