installing trunk torsion springs #2827108
09/30/20 09:16 PM
09/30/20 09:16 PM
Southeast PA
5wndwcpe Offline OP
5wndwcpe  Offline OP
Southeast PA
On a '68 B body convertible, can the trunk torsion springs be installed with the deck lid on ? I've futz with it for a bit and it seems the hinge arms are in the way.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: installing trunk torsion springs [Re: 5wndwcpe] #2827166
10/01/20 12:33 AM
10/01/20 12:33 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
These photos are A body but may be similar to your car. Without the deck lid looks to be easier. Having it bolted to the hinges doesn't appear to matter as long as the deck lid is up, but I've never tried that. Should be very difficult with the deck lid down. eek
The ends of the torsion bars that fit into the hinges are at the top of this photo. The top of the rod on the right fits into the right hinge. If the wrong one is put into the hinge, the anchor end will be clocked wrong.
Re: installing trunk torsion springs [Re: kentj340] #2827169
10/01/20 12:39 AM
10/01/20 12:39 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Follow the photos.
23-26 Deck Lid. R torsion rod re-install.jpg23-26 Deck Lid. R torsion rod re-install1.jpg23-26 Deck Lid. R torsion rod re-install2.jpg
Re: installing trunk torsion springs [Re: kentj340] #2827170
10/01/20 12:43 AM
10/01/20 12:43 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The clocking of the anchor end of the un-stressed rod in the 2nd photo below is with the hinge in about the closed lid position. In the 3rd photo below, the clocking is with the hinge raised.
23-26 Deck Lid. R torsion rod re-install3.jpg23-26 Deck Lid. R torsion rod re-install4.jpg23-26 deck lid. r torsion rod re-install5.jpg
Re: installing trunk torsion springs [Re: kentj340] #2827171
10/01/20 12:44 AM
10/01/20 12:44 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Use a crescent wrench to wind the bar to the anchor hole.
Re: installing trunk torsion springs [Re: kentj340] #2827220
10/01/20 08:50 AM
10/01/20 08:50 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Nice job on the instructions, KentJ, that should be in the Archives for future reference.
Joe
