installing trunk torsion springs
#2827108
09/30/20 09:16 PM
09/30/20 09:16 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
On a '68 B body convertible, can the trunk torsion springs be installed with the deck lid on ? I've futz with it for a bit and it seems the hinge arms are in the way.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: installing trunk torsion springs
[Re: 5wndwcpe]
#2827166
10/01/20 12:33 AM
10/01/20 12:33 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
These photos are A body but may be similar to your car. Without the deck lid looks to be easier. Having it bolted to the hinges doesn't appear to matter as long as the deck lid is up, but I've never tried that. Should be very difficult with the deck lid down. The ends of the torsion bars that fit into the hinges are at the top of this photo. The top of the rod on the right fits into the right hinge. If the wrong one is put into the hinge, the anchor end will be clocked wrong.
[Re: kentj340]
#2827170
10/01/20 12:43 AM
10/01/20 12:43 AM
kentj340
Cut and Shoot, TX
The clocking of the anchor end of the un-stressed rod in the 2nd photo below is with the hinge in about the closed lid position. In the 3rd photo below, the clocking is with the hinge raised.
[Re: kentj340]
#2827171
10/01/20 12:44 AM
10/01/20 12:44 AM
kentj340
Cut and Shoot, TX
Use a crescent wrench to wind the bar to the anchor hole.
