70 Challenger SE Door belt Molding clips #2825468
09/26/20 10:28 PM
09/26/20 10:28 PM
SE PA.
Q
QuickBpBp Offline OP
Q
SE PA.
Does anyone have pictures of what the door molding clips look like and how they install on the back of the door belt trim pieces? Thanks in advance!
Re: 70 Challenger SE Door belt Molding clips [Re: QuickBpBp] #2825474
09/26/20 10:47 PM
09/26/20 10:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
It's been quite some time since I did the trim on my car, but IIRC there's 4 different clips used on SE door trim, very hard to find decent intact clips, although there's a few aftermarket repro clips that can do the trick (Restoration Specialties) the door piece is tricky getting the sequence right due to the moldings taper... 7 clips total per door molding
hope this helps
Mike
Re: 70 Challenger SE Door belt Molding clips [Re: DAYCLONA] #2825477
09/26/20 11:02 PM
09/26/20 11:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Found these pics by Dwight, they should help, hate to say it but Jim Pati (Jims auto parts in NH) has a repro clip set listed for the 70-1 Challenger belt trim package..... pn# DM-CK-701CH for $300, I don't know if other vendors carry it, or if it's one of Pati's exclusive parts?
Mike
Re: 70 Challenger SE Door belt Molding clips [Re: DAYCLONA] #2825478
09/26/20 11:04 PM
09/26/20 11:04 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
And obviously this one is on the top edge rear of door just after the handle
Re: 70 Challenger SE Door belt Molding clips [Re: DAYCLONA] #2825486
09/26/20 11:26 PM
09/26/20 11:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Front of door hole/clip mldg...
Mike
Re: 70 Challenger SE Door belt Molding clips [Re: DAYCLONA] #2825490
09/26/20 11:33 PM
09/26/20 11:33 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Little clearer...
Re: 70 Challenger SE Door belt Molding clips [Re: DAYCLONA] #2825499
09/26/20 11:53 PM
09/26/20 11:53 PM
SE PA.
Q
Q
SE PA.
Thanks Mike!! I will post some nos clips I just got and I thought they might fit...They look like one in your pic but the "lever" is a different angle... Too late to do tonight but check back tomorrow. Thanks again they are tough to find info on..
Re: 70 Challenger SE Door belt Molding clips [Re: DAYCLONA] #2825500
09/26/20 11:54 PM
09/26/20 11:54 PM
Washington
hemienvy Online content
hemienvy  Online Content
Washington
Not to steal the thread, but is it similar for '70 Cuda with this trim ?
Re: 70 Challenger SE Door belt Molding clips [Re: hemienvy] #2825536
09/27/20 07:10 AM
09/27/20 07:10 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
No. They are plastic and readily available in several places. RT Speciality probably.
Re: 70 Challenger SE Door belt Molding clips [Re: fastmark] #2825539
09/27/20 07:30 AM
09/27/20 07:30 AM
Abilene, Texas
Abilene, Texas
I’m not sure anyone makes these yet. It’s been a much sought after item. I would sure want to see pictures of the ones from
Jim’s, with his reputation. The large clips at the back of the door and the two on the quarter panel were the last readily available. I think they are all gone from stock. Unless someone has stepped up to make them, I’d be surprised to find any new ones. Somome like me could have bought a bunch and hoarded them. I just barely have enough for my car. Nos cost me $100 for 10.The two at the front are different and almost impossible to find. The end one with the screw are usually still in the chrome, if someone took it off and was paying attention. The are very hard to get off without breaking them. You have to use a small deep socket and work from the back side.
Re: 70 Challenger SE Door belt Molding clips [Re: hemienvy] #2825617
09/27/20 12:37 PM
09/27/20 12:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
As mentioned the Cuda belt trim is held on by push pin plastic clips, on the Cuda you install the clips on the door/qtr first, them "snap" the molding onto the clips, the plastic clips are all the same size/shape door or qtr, the only clips you'll install on the door moldings before installing the moldings will be the metal stud clips that just slide in the rear of the molding at the end of the door to prevent the molding from sliding on the plastic clips once installed
Mike
Re: 70 Challenger SE Door belt Molding clips [Re: DAYCLONA] #2825624
09/27/20 12:44 PM
09/27/20 12:44 PM
Washington
Washington
Thanks for that !
The car has new sheet metal so there are no trim holes. I wasn't sure about the mounting method.
Re: 70 Challenger SE Door belt Molding clips [Re: fastmark] #2825633
09/27/20 12:58 PM
09/27/20 12:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Jim Pati has offered a lot of items over the decades that were his exclusive products, and sole source, I found his listing just out of curiosity during this thread to see if the clips were repro/offered by anyone as I know from personal experience how hard it is to find clips for the 70-71 SE/Formal trimmed Challengers...as far as Jim's Auto, I know, I know, I know, I've heard or read the issues some people have had with them over the decades, but personally I've never experienced any issues dealing with them over the decades, never lost money, never unhappy with the parts, always got what I wanted, and service/communication has never been an issue, but then again I'm usually thorough and final in my request when purchasing parts/service so as to avoid issues...I just wish some on my customers could be like that at times...lol!
Mike
Re: 70 Challenger SE Door belt Molding clips [Re: hemienvy] #2825638
09/27/20 01:09 PM
09/27/20 01:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks for that !
If you have nothing to measure/transfer the hole location from, what I've done in the past is locate the moldings on the car, mark the body on each side of the molding, find the center of those 2 marked lines to located the clips, space out the clip location, and drill the proper size hole to hold the clips, measure twice, drill once
Mike
Re: 70 Challenger SE Door belt Molding clips [Re: DAYCLONA] #2825675
09/27/20 03:14 PM
09/27/20 03:14 PM
SE PA.
Q
Q
SE PA.
Here they are. I think these are the 2 on the quarter and the 3 used on the door.. They look like that spring lever is just bent different maybe from installation. They are 1.5 inches wide from edge to edge... What do you think?
Re: 70 Challenger SE Door belt Molding clips [Re: QuickBpBp] #2825708
09/27/20 04:33 PM
09/27/20 04:33 PM
Abilene, Texas
Abilene, Texas
Ding, ding, ding. We have a winner! Those are the ones. You got lucky. Now for the bad news. Now you have to find the other ones. See the ones posted. I paid $10 each for mine three years ago.
Re: 70 Challenger SE Door belt Molding clips [Re: fastmark] #2825713
09/27/20 04:53 PM
09/27/20 04:53 PM
SE PA.
Q
Q
SE PA.
Thanks! I just bought a bunch of stuff from a old dealership I just wanted to verify so I can get rid of these...Thanks again for all the help and pics..
Re: 70 Challenger SE Door belt Molding clips [Re: QuickBpBp] #2825823
09/27/20 08:42 PM
09/27/20 08:42 PM
WV
Little Detroit Offline
WV
steve seigel has a set forsale on face book nos parts
Re: 70 Challenger SE Door belt Molding clips [Re: Little Detroit] #2825843
09/27/20 09:37 PM
09/27/20 09:37 PM
SE PA.
Q
Q
SE PA.
Just saw them on e-bay...$400 set
