New best, sneakin up on it!
#2825523
09/27/20 04:02 AM
09/27/20 04:02 AM
Posts: 9,986 Frostbitefalls MN (Rocky&Bullw...
gregsdart
BIR went 1/8th mile for the weekend due to weather/cold track. Best of 5.603 with a 1.265 60 ft. Mph was off at 122. Wierd, as there was no head wind and i clocked 124 mph on another pass. Pic is of a full pass on friday. DA on the 5.60 was 3195. Ugly for fall.
Re: New best, sneakin up on it! Update!
[Re: gregsdart]
#2825788
09/27/20 07:37 PM
09/27/20 07:37 PM
gregsdart
First round on saturday i hit the brakes hard and got a bad wobble after locking up the front brakes. I started looking through the front suspension and found a few things. A slightly loose upper ball joint on the passenger side, both outer tierod ends slightly worn, and for it to wobble like it did there is more wear hidden i am sure. I have to think this is related to the eratic acceleration graph from about 500 feet to 1000 feet.
[Re: Deepockets]
#2825831
09/27/20 08:52 PM
09/27/20 08:52 PM
gregsdart
Good job. What's your target you'd like to see. Don, trying to get it to go 8.60s. That may be a stretch, but i am hoping the worn front end was causing the erratic acceleration from about 500 to 1000 feet. That cold be worth .05 or a bit more? Good air is rare hear. Anything below 2000 DA is considered a good day!
[Re: gregsdart]
#2825930
09/28/20 08:42 AM
09/28/20 08:42 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Very nice Greg! I'd kill for that 60'! I went 5.60 at 126.5 mph w/ a 1.31 sixty foot last year...been trying to get back to a 1/4 mile track ever since, lol.
[Re: gregsdart]
#2826387
09/29/20 10:17 AM
09/29/20 10:17 AM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Good job. What's your target you'd like to see. Don, trying to get it to go 8.60s. That may be a stretch, but i am hoping the worn front end was causing the erratic acceleration from about 500 to 1000 feet. That cold be worth .05 or a bit more? Good air is rare hear. Anything below 2000 DA is considered a good day! “In theory”, you’ll need to be sitting on the starting line in good enough air to be making very close to 900 uncorrected HP for your weight of a nominal 3000lbs. And then........ have the car cooperate and do all the right things. @3000lbs, the Moroso chart shows it would take an additional 70hp to go from 8.86(825hp)to 8.65(895hp).
[Re: HardcoreB]
#2826501
09/29/20 03:29 PM
09/29/20 03:29 PM
gregsdart
Nice Greg. You figure out the hoodscoop package yet? Not yet. Weathet and worn parts shut me down after only a few runs. I did run a 5.603 with a 1.265 60 ft at 3194 da though. I was running a screen only and scoop, no hood.
[Re: fast68plymouth]
#2826635
09/29/20 08:10 PM
09/29/20 08:10 PM
gregsdart
Good job. What's your target you'd like to see. Don, trying to get it to go 8.60s. That may be a stretch, but i am hoping the worn front end was causing the erratic acceleration from about 500 to 1000 feet. That cold be worth .05 or a bit more? Good air is rare hear. Anything below 2000 DA is considered a good day! “In theory”, you’ll need to be sitting on the starting line in good enough air to be making very close to 900 uncorrected HP for your weight of a nominal 3000lbs. And then........ have the car cooperate and do all the right things. @3000lbs, the Moroso chart shows it would take an additional 70hp to go from 8.86(825hp)to 8.65(895hp). So this is whats up. Best run was an 1/8th mile, 5.603 with a 1.265 60 ft. Since it was heavy overcast and cold, i assume the track surface was a bit cold. DA was 3194. A spring outing to a lower elevation track like Rock falls (800 ft;bir 1210) should find some 1600 ft DA or better.i hope to get vacuum up from 4 inch to 10 or 12. Will post a pick of the acceleration graph that shows a problem, maybe a front end wobble. The 1/2 shift also shows a large dip which wasn't there in seasons past. Look at the sag in acceleration from about 5 sec to 8 sec. First graph is of a previous event, shows no dip on the shift but shows erratic acceleration
[Re: gregsdart]
#2826643
09/29/20 08:27 PM
09/29/20 08:27 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
You are running alky, right? I doubt the ET numbers are going to move around much, especially compared to gas, even with some DA change
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2826651
09/29/20 08:49 PM
09/29/20 08:49 PM
gregsdart
You are running alky, right? I doubt the ET numbers are going to move around much, especially compared to gas, even with some DA change 400 to 450 ft da change seems to equal .01 for me. Gas is about 250. So hear is my hoped for gains; DA of 1600 or better ,,,,,,,,. .04 Fix front end wobble,,,..... .03? 1/2 shift fix,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,.03? Better 60 ft ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,.01? Tuning?,,,,,,,,,,,?.02? Maybe .13 total which would produce an 8.72. I'd take that. Oh, forgot porky tear needs to drop 50 lbs- gauranteed .04! There would be my 8.6-
