oil pressure gauge flutter #2823723
09/22/20 05:32 PM
09/22/20 05:32 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
just recently noticed when motor is hot above 45psi / 2600rpm there is a slight flutter/buzz of the gauge . Not much maybe 2-5 psi . Autometer mechanical gauge with i think a -6 braided line
No problem cold . No problem at idle hot or on deceleration .
I noticed it , then oil and filter change as was due , still there .
I use RP 20/50 and use K&N HP filter .
I split the old filter , no jewellry .
I will pull the relief valve later this week and check its not sticky .
Its a World block , flat tappet cam
Can maybe try a different filter , maybe a Baldwin B2 ?
What are your thoughts ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: oil pressure gauge flutter [Re: tex013] #2825250
09/26/20 10:26 AM
09/26/20 10:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a smaller restriction in your oil line/gauge it will smoothen it out.. had to do this in the lab a
lot of times
wave
Re: oil pressure gauge flutter [Re: tex013] #2825251
09/26/20 10:31 AM
09/26/20 10:31 AM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
Tex
Is that a typo ? -6 is a big line for a gauge. -4 or -3 will smooth out the gauge. If you are using -6 it will make the gauge much more responsive, but if thats the case why the worry?? 2-5psi is not a big swing and it really is happening anyway, you just wouldnt notice it with the smaller dia line.
....BAD A$$ STREET CAR.....
Re: oil pressure gauge flutter [Re: n20mstr] #2825286
09/26/20 12:14 PM
09/26/20 12:14 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
-3 on my mechanical pressure gauges. Always.
Re: oil pressure gauge flutter [Re: n20mstr] #2825515
09/27/20 01:02 AM
09/27/20 01:02 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Is that a typo ? -6 is a big line for a gauge. -4 or -3 will smooth out the gauge. If you are using -6 it will make the gauge much more responsive, but if thats the case why the worry?? 2-5psi is not a big swing and it really is happening anyway, you just wouldnt notice it with the smaller dia line. [/quote]
DUH , its a -3 or -4 . Sorry about that .
Thanks guys
Tex
New best MPH 130.32
Re: oil pressure gauge flutter [Re: tex013] #2825611
09/27/20 12:21 PM
09/27/20 12:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
-3 is more responsive to changes. Tells you what is really happening. Less oil to dampen the signal between the source and the gauge.
Re: oil pressure gauge flutter [Re: CMcAllister] #2825627
09/27/20 12:47 PM
09/27/20 12:47 PM
I switch one of my bracket cars to a 1/4 inch oil pressure line from the standard 1/16 or 1/8 (CRS) with the same gauge, the bigger line made the gauge a lot more responsive to the oil pressure changes up It changed with RPM just like the tach did shruggy
NHRA outlaw the bigger line shortly after I made that change whiney I never changed it and was never question by 8 or 9 different track NHRA techs about it either shruggy
Re: oil pressure gauge flutter [Re: Cab_Burge] #2825739
09/27/20 05:43 PM
09/27/20 05:43 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks
Tex
New best MPH 130.32
