oil pressure gauge flutter
#2823723
09/22/20 05:32 PM
09/22/20 05:32 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
just recently noticed when motor is hot above 45psi / 2600rpm there is a slight flutter/buzz of the gauge . Not much maybe 2-5 psi . Autometer mechanical gauge with i think a -6 braided line No problem cold . No problem at idle hot or on deceleration . I noticed it , then oil and filter change as was due , still there . I use RP 20/50 and use K&N HP filter . I split the old filter , no jewellry . I will pull the relief valve later this week and check its not sticky . Its a World block , flat tappet cam Can maybe try a different filter , maybe a Baldwin B2 ? What are your thoughts ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: oil pressure gauge flutter
[Re: tex013]
#2825251
09/26/20 10:31 AM
09/26/20 10:31 AM
Posts: 4,670 On the parachute mount
n20mstr
Tex Is that a typo ? -6 is a big line for a gauge. -4 or -3 will smooth out the gauge. If you are using -6 it will make the gauge much more responsive, but if thats the case why the worry?? 2-5psi is not a big swing and it really is happening anyway, you just wouldnt notice it with the smaller dia line.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2825286
09/26/20 12:14 PM
09/26/20 12:14 PM
Posts: 11,497 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
-3 on my mechanical pressure gauges. Always.
[Re: n20mstr]
#2825515
09/27/20 01:02 AM
09/27/20 01:02 AM
tex013
Sydney,Australia
Is that a typo ? -6 is a big line for a gauge. -4 or -3 will smooth out the gauge. If you are using -6 it will make the gauge much more responsive, but if thats the case why the worry?? 2-5psi is not a big swing and it really is happening anyway, you just wouldnt notice it with the smaller dia line. [/quote]
DUH , its a -3 or -4 . Sorry about that . Thanks guys
Tex
[Re: tex013]
#2825611
09/27/20 12:21 PM
09/27/20 12:21 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
-3 is more responsive to changes. Tells you what is really happening. Less oil to dampen the signal between the source and the gauge.
[Re: CMcAllister]
#2825627
09/27/20 12:47 PM
09/27/20 12:47 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
I switch one of my bracket cars to a 1/4 inch oil pressure line from the standard 1/16 or 1/8 (CRS) with the same gauge, the bigger line made the gauge a lot more responsive to the oil pressure changes It changed with RPM just like the tach did NHRA outlaw the bigger line shortly after I made that change I never changed it and was never question by 8 or 9 different track NHRA techs about it either
