What slicks to get #2823684
09/22/20 04:01 PM
09/22/20 04:01 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
3900# car/driver,1.35 60' ,some trans brake use,3.73 gear w/spool,I have been using M/T ET Drag 29.5 10.5 15S D5 compound with tubes nd 10# air on 10"x15 rims w/screws.I have QA-1 shocks in back/cal tracs,3way front.I feel what I have been using has been good but maybe softer would help/grip.My vert is 4500 th400,t brake any gear.2.46,1.45.1/1 3rd
TIA
I will not get out till next yr but making plans
Re: What slicks to get [Re: Clanton] #2823717
09/22/20 05:23 PM
09/22/20 05:23 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
you could try the Pro Bracket Radial .
I use the 29.5x10.5 PBR on my Satellite , leave on tbrake@4500 , 15x10 rim
A mate runs them on is 62 Chev , 15x 8.5 rim . He is around 3900lbs , 540ci W motor , tbrake launch
I glue the tyres
I go low mid 1.40s , he goes low 1.40s
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: What slicks to get [Re: tex013] #2823775
09/22/20 07:04 PM
09/22/20 07:04 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Your info is in line with mine but I don't know if I want to get on the band wagon[reluctant to change]I will read more on it Thank you!
Re: What slicks to get [Re: Clanton] #2823964
09/23/20 10:09 AM
09/23/20 10:09 AM
an8sec70cuda Offline
If you don't want to try a radial, then I'd stick w/ what you have. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What slicks to get [Re: Clanton] #2823988
09/23/20 10:57 AM
09/23/20 10:57 AM
NC
440Jim Offline
440Jim  Offline
NC
I like the M/T ET Drags for your application. weight, perf, size
From what I have seen, their 10.5 tires are pretty good.
I am a little surprised you run that low air pressure. I would think you could run 14-15 psi
Re: What slicks to get [Re: 440Jim] #2824008
09/23/20 11:35 AM
09/23/20 11:35 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I agree, the ET Drag is what I am comfortable with using and to be honest I forget the air psi I used it has been about 4yrs and you are most likely correct.
Re: What slicks to get [Re: Clanton] #2824066
09/23/20 01:07 PM
09/23/20 01:07 PM
New York, USA
Chargerfan68 Offline
New York, USA
We are very similar.....3900 lbs, MT ET drag slick 28x11.5-15 on 10x15. I run 1.49-1.50 most times. I have tested pressures in 1/2 lb increments and my setup seems to like 13 lbs exactly. I run tubes with screws and all the sets i’ve run over the years had very very consistent performance.
Re: What slicks to get [Re: Clanton] #2824122
09/23/20 02:18 PM
09/23/20 02:18 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Bias ply guy here for years, 'til I tried some pro drag radials, grin
I'm not going back if I can help it wink up
Re: What slicks to get [Re: Tig] #2824144
09/23/20 02:53 PM
09/23/20 02:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Nothing wrong with having success.
Re: What slicks to get [Re: Clanton] #2824151
09/23/20 03:07 PM
09/23/20 03:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My suggestion is put that same tire on a wider wheel. A 10" wheel really is to narrow for that tire. Plenty of folks going low 1.teen 60's NA with that tire but on a wider wheel to spread the tire out
Re: What slicks to get [Re: Al_Alguire] #2824167
09/23/20 03:33 PM
09/23/20 03:33 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have no room for a wider rim with factory wheel wells but I do get a good use of the contact and only a little wrinkle without it pulling on the tread patch.ty
Re: What slicks to get [Re: Clanton] #2824391
09/24/20 12:51 AM
09/24/20 12:51 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I’m very happy with my PBR’s. Currently running 28x9’s in the stock 67 B-body wheelhouse. Going on year 3 with these, prob. In the range of 150 runs on them, and they still look like they’ve got a full season left in them. My car was also quicker & faster with them vs ET Drags, and the consistency is impressive.
Re: What slicks to get [Re: StealthWedge67] #2824647
09/24/20 04:28 PM
09/24/20 04:28 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks for the info!
