What slicks to get
#2823684
09/22/20 04:01 PM
09/22/20 04:01 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
3900# car/driver,1.35 60' ,some trans brake use,3.73 gear w/spool,I have been using M/T ET Drag 29.5 10.5 15S D5 compound with tubes nd 10# air on 10"x15 rims w/screws.I have QA-1 shocks in back/cal tracs,3way front.I feel what I have been using has been good but maybe softer would help/grip.My vert is 4500 th400,t brake any gear.2.46,1.45.1/1 3rd TIA I will not get out till next yr but making plans
Re: What slicks to get
[Re: Clanton]
#2823717
09/22/20 05:23 PM
09/22/20 05:23 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
you could try the Pro Bracket Radial . I use the 29.5x10.5 PBR on my Satellite , leave on tbrake@4500 , 15x10 rim A mate runs them on is 62 Chev , 15x 8.5 rim . He is around 3900lbs , 540ci W motor , tbrake launch I glue the tyres I go low mid 1.40s , he goes low 1.40s
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Clanton]
#2823964
09/23/20 10:09 AM
09/23/20 10:09 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
If you don't want to try a radial, then I'd stick w/ what you have.
[Re: Clanton]
#2823988
09/23/20 10:57 AM
09/23/20 10:57 AM
Posts: 16,925 NC
440Jim
NC
I like the M/T ET Drags for your application. weight, perf, size From what I have seen, their 10.5 tires are pretty good. I am a little surprised you run that low air pressure. I would think you could run 14-15 psi
[Re: Clanton]
#2824066
09/23/20 01:07 PM
09/23/20 01:07 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
We are very similar.....3900 lbs, MT ET drag slick 28x11.5-15 on 10x15. I run 1.49-1.50 most times. I have tested pressures in 1/2 lb increments and my setup seems to like 13 lbs exactly. I run tubes with screws and all the sets i’ve run over the years had very very consistent performance.
[Re: Clanton]
#2824122
09/23/20 02:18 PM
09/23/20 02:18 PM
Posts: 2,919 A shed in England
Tig
A shed in England
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Clanton]
#2824151
09/23/20 03:07 PM
09/23/20 03:07 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
My suggestion is put that same tire on a wider wheel. A 10" wheel really is to narrow for that tire. Plenty of folks going low 1.teen 60's NA with that tire but on a wider wheel to spread the tire out
[Re: Al_Alguire]
#2824167
09/23/20 03:33 PM
09/23/20 03:33 PM
Clanton
northern,Ohio,USA
I have no room for a wider rim with factory wheel wells but I do get a good use of the contact and only a little wrinkle without it pulling on the tread patch.ty My suggestion is put that same tire on a wider wheel. A 10" wheel really is to narrow for that tire. Plenty of folks going low 1.teen 60's NA with that tire but on a wider wheel to spread the tire out
[Re: Clanton]
#2824391
09/24/20 12:51 AM
09/24/20 12:51 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I’m very happy with my PBR’s. Currently running 28x9’s in the stock 67 B-body wheelhouse. Going on year 3 with these, prob. In the range of 150 runs on them, and they still look like they’ve got a full season left in them. My car was also quicker & faster with them vs ET Drags, and the consistency is impressive.
