Double adjustable rear shocks for street/strip? #2823734
09/22/20 05:48 PM
09/22/20 05:48 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I'm going to upgrade over the winter to double adjustable rear shocks.
I currently have the Calvert/Rancho 9 way single adjustable.
Looking at Afco, Viking and Jegs price point of shocks.
This is for the street/strip 330 with Cal-Tracs and 275 drag radials.
We welded on a new upper mount to get the shocks more vertical so it made the shock requirement shorter.
My questions are:
1. Which is the best shock for my application?
2. Since it's not a stock length, do I measure for length with the car at ride height and then full extension?
3. Do they only come with the spherical rod end mounting and are there any issues with that?
'63 Dodge 330
11.19 @ 121 mph
Re: Double adjustable rear shocks for street/strip? [Re: GY3] #2823788
09/22/20 07:31 PM
09/22/20 07:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have no problem with Viking shocks, call them and they'll advise you on what shock is best for you're application.
Re: Double adjustable rear shocks for street/strip? [Re: justinp61] #2823816
09/22/20 08:22 PM
09/22/20 08:22 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
my Vikings are great .
im sure with measurement they could set you up .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Double adjustable rear shocks for street/strip? [Re: tex013] #2823852
09/22/20 09:28 PM
09/22/20 09:28 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
AFCO , strange or Santuff
....BAD A$$ STREET CAR.....
Re: Double adjustable rear shocks for street/strip? [Re: n20mstr] #2823853
09/22/20 09:31 PM
09/22/20 09:31 PM
N
n20mstr Offline
n20mstr  Offline
N
Yes when ordering
You need fully
Extended and ride height
Numbers . You looking for 4” or more of extension
Re: Double adjustable rear shocks for street/strip? [Re: n20mstr] #2823854
09/22/20 09:34 PM
09/22/20 09:34 PM
N
n20mstr Offline
n20mstr  Offline
N
The best shock will be the one that offers the most control . Especially on extension . Mopar slings short front segment means a short instant center . More power needs more control means real stiff on the extension
Re: Double adjustable rear shocks for street/strip? [Re: n20mstr] #2823882
09/22/20 11:49 PM
09/22/20 11:49 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Yes, it's at #9 setting on the Calvert shock now and it needs stiffer. It does fine on well prepped tracks but anything less is hit and miss.
'63 Dodge 330
11.19 @ 121 mph
Re: Double adjustable rear shocks for street/strip? [Re: GY3] #2823891
09/23/20 12:46 AM
09/23/20 12:46 AM
gregsdart Offline
gregsdart  Offline
Consider n20mstr 's comment and more. Figure out where your racing future will be years down the road. A costly double adjustable isn't so costly if you end up upgrading three times! Also consider any suspension changes you may make in the future. I run ladderbars. With 920 hp and they are VIOLENT. Better to gave too wide a range of adjustment than not enough.
Re: Double adjustable rear shocks for street/strip? [Re: gregsdart] #2823962
09/23/20 10:07 AM
09/23/20 10:07 AM
an8sec70cuda Offline
Buy what you can afford. I'm sure the expensive ones are great, but I've been happy w/ my Vikings so far. I may outgrow them, but we'll see.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Double adjustable rear shocks for street/strip? [Re: an8sec70cuda] #2823977
09/23/20 10:24 AM
09/23/20 10:24 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Good thing about Viking shocks. They are easily re-valved.
Re: Double adjustable rear shocks for street/strip? [Re: an8sec70cuda] #2824009
09/23/20 11:37 AM
09/23/20 11:37 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Did you buy your Vikings directly from them?
'63 Dodge 330
11.19 @ 121 mph
Re: Double adjustable rear shocks for street/strip? [Re: GY3] #2824040
09/23/20 12:24 PM
09/23/20 12:24 PM
Yes.
CHIP
Re: Double adjustable rear shocks for street/strip? [Re: an8sec70cuda] #2824093
09/23/20 01:38 PM
09/23/20 01:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I'll put in another good word for Viking. I just run their standard DA shock on mine and have been happy with them. My car has been a best 60FT of 1.41@3550lbs
The Biggest eye opener I had for DA shocks was on Drag Week 2018 on the last day. I went my best 60ft in time trials of 1.41. Much later in the day 1st round of elimination for my class I went a 1.65 and had to steer the car even, still won the round. The track was absolute garbage and with a few adjustments I got the 60s down to low 1.5s and made it down to 4 cars. I don't think there was anything I could have done to get the low 1.4s back but it was nice to see the adjustments work each round.
68 Barracuda Formula S 340
Re: Double adjustable rear shocks for street/strip? [Re: GY3] #2824108
09/23/20 01:57 PM
09/23/20 01:57 PM
I had single adjustable Strange rear coil overs on my old pump gas Duster that work fine for street duty, I ended up swapping them to the same shock with double adjustable which was a good thing, especially at the tracks up
Re: Double adjustable rear shocks for street/strip? [Re: an8sec70cuda] #2824126
09/23/20 02:22 PM
09/23/20 02:22 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Yes.
Warrior or Crusader series?
'63 Dodge 330
11.19 @ 121 mph
