Double adjustable rear shocks for street/strip?
#2823734
09/22/20 05:48 PM
09/22/20 05:48 PM
Posts: 4,703 Wichita
GY3
Wichita
I'm going to upgrade over the winter to double adjustable rear shocks.
I currently have the Calvert/Rancho 9 way single adjustable.
Looking at Afco, Viking and Jegs price point of shocks.
This is for the street/strip 330 with Cal-Tracs and 275 drag radials.
We welded on a new upper mount to get the shocks more vertical so it made the shock requirement shorter.
My questions are:
1. Which is the best shock for my application?
2. Since it's not a stock length, do I measure for length with the car at ride height and then full extension?
3. Do they only come with the spherical rod end mounting and are there any issues with that?
Re: Double adjustable rear shocks for street/strip?
[Re: justinp61]
#2823816
09/22/20 08:22 PM
09/22/20 08:22 PM
Posts: 2,473 Sydney,Australia
tex013
Sydney,Australia
my Vikings are great . im sure with measurement they could set you up .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: n20mstr]
#2823853
09/22/20 09:31 PM
09/22/20 09:31 PM
Posts: 4,698 On the parachute mount
n20mstr
Yes when ordering You need fully Extended and ride height Numbers . You looking for 4” or more of extension
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2823854
09/22/20 09:34 PM
09/22/20 09:34 PM
n20mstr
The best shock will be the one that offers the most control . Especially on extension . Mopar slings short front segment means a short instant center . More power needs more control means real stiff on the extension
[Re: n20mstr]
#2823882
09/22/20 11:49 PM
09/22/20 11:49 PM
GY3
Wichita
The best shock will be the one that offers the most control . Especially on extension . Mopar slings short front segment means a short instant center . More power needs more control means real stiff on the extension Yes, it's at #9 setting on the Calvert shock now and it needs stiffer. It does fine on well prepped tracks but anything less is hit and miss.
[Re: GY3]
#2823891
09/23/20 12:46 AM
09/23/20 12:46 AM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The best shock will be the one that offers the most control . Especially on extension . Mopar slings short front segment means a short instant center . More power needs more control means real stiff on the extension Yes, it's at #9 setting on the Calvert shock now and it needs stiffer. It does fine on well prepped tracks but anything less is hit and miss. Consider n20mstr 's comment and more. Figure out where your racing future will be years down the road. A costly double adjustable isn't so costly if you end up upgrading three times! Also consider any suspension changes you may make in the future. I run ladderbars. With 920 hp and they are VIOLENT. Better to gave too wide a range of adjustment than not enough.
[Re: gregsdart]
#2823962
09/23/20 10:07 AM
09/23/20 10:07 AM
Posts: 13,390 Marion, South Carolina [><]
an8sec70cuda
Buy what you can afford. I'm sure the expensive ones are great, but I've been happy w/ my Vikings so far. I may outgrow them, but we'll see.
[Re: an8sec70cuda]
#2823977
09/23/20 10:24 AM
09/23/20 10:24 AM
Posts: 1,841 NW Indiana
fbs63
NW Indiana
Buy what you can afford. I'm sure the expensive ones are great, but I've been happy w/ my Vikings so far. I may outgrow them, but we'll see. Good thing about Viking shocks. They are easily re-valved.
[Re: an8sec70cuda]
#2824009
09/23/20 11:37 AM
09/23/20 11:37 AM
GY3
Wichita
Buy what you can afford. I'm sure the expensive ones are great, but I've been happy w/ my Vikings so far. I may outgrow them, but we'll see. Did you buy your Vikings directly from them?
[Re: GY3]
#2824040
09/23/20 12:24 PM
09/23/20 12:24 PM
an8sec70cuda
Buy what you can afford. I'm sure the expensive ones are great, but I've been happy w/ my Vikings so far. I may outgrow them, but we'll see. Did you buy your Vikings directly from them? Yes.
[Re: an8sec70cuda]
#2824093
09/23/20 01:38 PM
09/23/20 01:38 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I'll put in another good word for Viking. I just run their standard DA shock on mine and have been happy with them. My car has been a best 60FT of 1.41@3550lbs
The Biggest eye opener I had for DA shocks was on Drag Week 2018 on the last day. I went my best 60ft in time trials of 1.41. Much later in the day 1st round of elimination for my class I went a 1.65 and had to steer the car even, still won the round. The track was absolute garbage and with a few adjustments I got the 60s down to low 1.5s and made it down to 4 cars. I don't think there was anything I could have done to get the low 1.4s back but it was nice to see the adjustments work each round.
68 Barracuda Formula S 340
[Re: an8sec70cuda]
#2824126
09/23/20 02:22 PM
09/23/20 02:22 PM
GY3
Wichita
Buy what you can afford. I'm sure the expensive ones are great, but I've been happy w/ my Vikings so far. I may outgrow them, but we'll see. Did you buy your Vikings directly from them? Yes. Warrior or Crusader series?
