Aftermarket Calipers #2822814
09/20/20 07:49 AM
09/20/20 07:49 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Hey everyone. I am trying to get my disc brake setup pieced together (11.75" Cordoba rotor upgrade) and I noticed that the slider type calipers that Dr. Diff's bracket requires are hard to come by. Of course my Charger has the pin types which I am guessing won't work.
Searching around, I found these on Ebay:
https://www.ebay.com/itm/282555496770
They appear to be new repro's of the calipers I need, come loaded, and are red powder coated. This seems like a very fair price for all this. Has anybody every used these before? Any issues with these?
I am hoping these are at least as good as all the remans out here. I could care less about the red powdercoat but this at least saves me the trouble of having to paint them myself.
Of course I am hoping and praying that this setup clears me 15" Magnum 500's. luck
Re: Aftermarket Calipers [Re: cjskotni] #2822819
09/20/20 08:54 AM
09/20/20 08:54 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Not sure why you think slider calipers are hard to come by, they were in production much longer than the pin types, all the way till the end of M body production in 89. Reman ones are readily available and Doc DIff sell news ones for a similar price.
Re: Aftermarket Calipers [Re: Sniper] #2822820
09/20/20 08:58 AM
09/20/20 08:58 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
For some reason all the parts stores don't have them (even rockauto). Dr. Diff was out of stock until yesterday.
Re: Aftermarket Calipers [Re: cjskotni] #2822836
09/20/20 09:46 AM
09/20/20 09:46 AM
nowhere
nowhere
Odd, I just looked at RA and they had plenty. 89 Diplomat.
What application were you looking at? there are a couple different bore sizes, wonder if you were looking at an oddball one?
Re: Aftermarket Calipers [Re: cjskotni] #2822843
09/20/20 10:02 AM
09/20/20 10:02 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have the pin type and noticed that they weren't listed for a RR, so I had to have them look other body names, like Satellite and so forth. Remember that parts store people don't know anything about cars, so you just about have to do it for them.
Re: Aftermarket Calipers [Re: Sniper] #2822872
09/20/20 11:27 AM
09/20/20 11:27 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
I was looking for a 78 Cordoba.
Re: Aftermarket Calipers [Re: cjskotni] #2822893
09/20/20 12:42 PM
09/20/20 12:42 PM
nowhere
nowhere
Hmm, RA shows those to have phenolic pistons, the Diplomat ones I looked at are metal. That might be the issue.
Re: Aftermarket Calipers [Re: Sniper] #2822970
09/20/20 04:33 PM
09/20/20 04:33 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The 76 77 F body calipers were hard to find when I was looking for them. New ones are available on ebay . The feed back I got from a friend was they worked fine and he was happy with them. I`m not sure what year they changed but the hose and bleeder location was different in the later years IIRC.
Re: Aftermarket Calipers [Re: cjskotni] #2822972
09/20/20 04:36 PM
09/20/20 04:36 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Rockauto can get the calipers in stock, but not the brackets. That's not part of a replacement or mantenience system to have them in stock on a regular replacement parts shop, just on Mopar dealers, and nowdays at repro &/or performance market or used.
Slider caliper brackets are not really hard to get, Pin kind are nearly imposible thought ( and when they float on, on outrageous prices ).
Cass at Doctor dif is not the only source but also the Ramman. He uses to have both kind.
Re: Aftermarket Calipers [Re: NachoRT74] #2825335
09/26/20 02:21 PM
09/26/20 02:21 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Yup, I got the brackets from Dr. Diff and my parts are coming in - now I am worried this new setup won't clear my 15" Wheel Vintique's Magnum 500's.
I did stick the rotors in the rear tires (same rims as front) and there isn't much room to spare. There is a max of 1.5" from the edge of the rim to the rotor. This setup is supposed to clear 15" rims. Does anybody have any experience with this setup and rims like mine who can confirm whether or not this will clear?
Right now, the rear of my Charger is off the ground (rebuilding the diff) so I can't get my front tires off to measure my existing front calipers. luck
Re: Aftermarket Calipers [Re: cjskotni] #2825345
09/26/20 03:13 PM
09/26/20 03:13 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Those wheels will clear 11.75" front brakes.
I own the tooling for reproduction 11.75" slider caliper brackets.
I also carry new slider calipers with 2 bleeder valves so they can be mounted toward the front or rear of the vehicle. See below:
https://www.doctordiff.com/73-89-slider-calipers.html
Re: Aftermarket Calipers [Re: DoctorDiff] #2825368
09/26/20 04:46 PM
09/26/20 04:46 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Thanks for responding. I just purchased your brackets last week and I would have purchased the calipers from you but, at the time, your were out of stock. The brakes on this car were never "bad" considering the era of car but I am hoping I get a little extra stopping power that I can feel vs. my stock front brakes. thumbs
Re: Aftermarket Calipers [Re: cjskotni] #2834154
10/18/20 10:21 AM
10/18/20 10:21 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
All,
Well I got the gumption up and swapped to the new brakes. This is my first experience with the sliding calipers so hoping I got these clips on correctly. luck
I was able to get these to clear my 15" rims but I had to have the weights moved to the outside of the rim as there was just an ever slight scrubbing with the inside weights.
Re: Aftermarket Calipers [Re: cjskotni] #2834202
10/18/20 12:43 PM
10/18/20 12:43 PM
BDW Offline
BDW  Offline
Looks good, report back how it stops.
Re: Aftermarket Calipers [Re: BDW] #2840927
11/02/20 08:28 PM
11/02/20 08:28 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Well after bleeding the brakes once, tearing down the rear brakes (SSBC disc conversion), finding the (rear) hard lines plugged with rust/crap, blowing all that out, bleeding again, replacing the rubber lines all all four tires, and then bleeding a 3rd time, yes it stops pretty well. I'd say incrementally better than before - but not night/day. However, I will say it is approaching the brakes of a modern day car.
