Re: Car keeps shutting off
[Re: JFChallenger440]
#2822657
09/19/20 04:33 PM
09/19/20 04:33 PM
Posts: 10,757 North Dakota
6PakBee
North Dakota
Do you still have the point ignition or have you "upgraded" to the Mopar electronic version?
#2822661
09/19/20 04:41 PM
09/19/20 04:41 PM
Posts: 8,407 Highland, MI.
Sunroofcuda
Highland, MI.
With the car running, jiggle the wires to the ballast resistor. If it shuts off, it's the resistor. A $3.00 part.
#2822667
09/19/20 05:02 PM
09/19/20 05:02 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Double check the bulkhead connectors.. These are frequently damaged and/or oxidized.. Just my $0.02...
[Re: moparjim79]
#2822883
09/20/20 12:04 PM
09/20/20 12:04 PM
Posts: 1,637 Florida
GMP440
Has your car been converted to electronic ignition? If so , check the plug going to the electronic ecu box. Make sure it's in all the way and the little bolt is tight. Recently, I had a no start condition. Had no spark going to the spark plugs. Noticed the plug going to the electronic was a little loose and the bolt, I was able turn by hand. Unplugged it , put it back on and tightened the bolt. Car fired right up. This was on my 68 Coronet. May or may not be the problem for you; but, it's an easy thing to check.
[Re: poorboy]
#2823207
09/21/20 10:43 AM
09/21/20 10:43 AM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
i had a customers car a few years back that would die every time the right door was closed. Drove him nuts fr awhile so he brought it in. LOL Long story. The culprit was the female bullet that supplies V to the control box was recessed when the plug was molded and barley touching the male pin. New harness plug and end of problem He had bought everything new from year one. They actually refunded the invoice amount to him.
[Re: burdar]
#2823271
09/21/20 01:02 PM
09/21/20 01:02 PM
RapidRobert
you did say not likely fuel but E10 with a carb will do that. plumbing a can of good gas to the pump inlet would confirm/deny that potential. switch the pump to non ethanol then pump several or more gallons into the car then some into the gas can cuz when you switch the pump to a different blend there is still some of the previous type in the pump hose/lines. might not be much but we want nothing left to chance.
