Car keeps shutting off #2822648
09/19/20 03:41 PM
09/19/20 03:41 PM
London, England
JFChallenger440 Offline OP
London, England
I have a problem on my 70 Satellite where the car keeps shutting off , it will only happen once or twice on a run out and it usually happens when idling , eg at the traffic lights or traffic jam
Initially I thought it only does it when slightly cold but today it did it at full operating temperature
It doesn’t splutter and shut off like a fuel problem , it shuts off just like if you were to turn the ignition off
The car usually will start up right away again ok
Any ideas ? Many thanks
Re: Car keeps shutting off [Re: JFChallenger440] #2822657
09/19/20 04:33 PM
09/19/20 04:33 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Do you still have the point ignition or have you "upgraded" to the Mopar electronic version?
Re: Car keeps shutting off [Re: JFChallenger440] #2822661
09/19/20 04:41 PM
09/19/20 04:41 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
With the car running, jiggle the wires to the ballast resistor. If it shuts off, it's the resistor. A $3.00 part.
Re: Car keeps shutting off [Re: JFChallenger440] #2822667
09/19/20 05:02 PM
09/19/20 05:02 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Double check the bulkhead connectors..
These are frequently damaged and/or oxidized..
Just my $0.02... wink
Re: Car keeps shutting off [Re: Sinitro] #2822685
09/19/20 06:28 PM
09/19/20 06:28 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Had a problem like that as well, turned out to be a float adjustment in my carb. Had a 750 mech secs., ran like a beast but would cook out randomly, only found the problem when I had the hood up with the air cleaner off cranking engine after it petered out.
Re: Car keeps shutting off [Re: moparjim79] #2822883
09/20/20 12:04 PM
09/20/20 12:04 PM
GMP440 Offline
GMP440  Offline
Has your car been converted to electronic ignition? If so , check the plug going to the electronic ecu box. Make sure it's in all the way and the little bolt is tight. Recently, I had a no start condition.
Had no spark going to the spark plugs. Noticed the plug going to the electronic was a little loose and the bolt, I was able turn by hand. Unplugged it , put it back on and tightened the bolt. Car fired right up. This was on my 68 Coronet.
May or may not be the problem for you; but, it's an easy thing to check.
Re: Car keeps shutting off [Re: GMP440] #2823083
09/20/20 09:42 PM
09/20/20 09:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I ran into that issue with a 69 Chrysler Newport. After months of chasing it, I figured out I had a couple wires going through the bulkhead connector that wasn't making good contact. The wires in my case were from inside the car. I pulled it apart and cleaned it with electrical cleaner, reassembled it, then pushed all the ends into the bulkhead connector from under the dash. I never had a problem after that. Gene
Re: Car keeps shutting off [Re: poorboy] #2823207
09/21/20 10:43 AM
09/21/20 10:43 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
i had a customers car a few years back that would die every time the right door was closed. Drove him nuts fr awhile so he brought it in. LOL Long story.
The culprit was the female bullet that supplies V to the control box was recessed when the plug was molded and barley touching the male pin. New harness plug and end of problem smile
He had bought everything new from year one. They actually refunded the invoice amount to him. beer
Re: Car keeps shutting off [Re: TJP] #2823217
09/21/20 11:22 AM
09/21/20 11:22 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You need to do some testing. The blue wire that comes from the ignition switch has power in the "run" position. This wire goes to the ballast and the coil. Start by checking the flat connector at the base of the steering column. Wiggle the connector and make sure you have power accross it. If that's good, move to the bulkhead connector. Test both sides of that and make sure you have good contact there. If that's good, move to the ballast. Make sure the blue wire has power in the "run" position. All connections need to be tight and free from moisture. Adding some dielectric grease to all electrical contacts is a good idea.
Re: Car keeps shutting off [Re: burdar] #2823271
09/21/20 01:02 PM
09/21/20 01:02 PM
you did say not likely fuel but E10 with a carb will do that. plumbing a can of good gas to the pump inlet would confirm/deny that potential. switch the pump to non ethanol then pump several or more gallons into the car then some into the gas can cuz when you switch the pump to a different blend there is still some of the previous type in the pump hose/lines. might not be much but we want nothing left to chance.
