drum to disc on e body? #2821431
09/16/20 10:01 AM
09/16/20 10:01 AM
N.Y.
sixpacksteve Offline OP
N.Y.
ok, What will i need to convert from a-b body to e body, spindles, rotors, calipers etc..?
Hell Hath No Fury Like Mine
Re: drum to disc on e body? [Re: sixpacksteve] #2821435
09/16/20 10:10 AM
09/16/20 10:10 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
check out Dr. Diff website . . . Cass has what you need . . .
Re: drum to disc on e body? [Re: a12rag] #2821441
09/16/20 10:20 AM
09/16/20 10:20 AM
N.Y.
N.Y.
hoping to to it off parts cars, what parts will work off which car?
Re: drum to disc on e body? [Re: sixpacksteve] #2821445
09/16/20 10:24 AM
09/16/20 10:24 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Online content
moparmike1  Online Content
I think this is what you're looking for:
https://www.allpar.com/history/mopar/brakes/disc-main.html
Mike.
Re: drum to disc on e body? [Re: sixpacksteve] #2821517
09/16/20 12:41 PM
09/16/20 12:41 PM
a12rag Offline
a12rag  Offline
There are many out there that would poo poo it, but go with F, M, J body spindles, rotors, calipers . . . they used to be pretty plentiful, and they do work. I would get the stainless steel braided brake lines (Dr. Diff) . . .if you "can" find" a mid 70's B body, then you could get the caliper adapter that would allow you to go with the 11.75" rotor. Although the smaller rotor still has better stopping than front drum brakes. Anyhow, good luck . . .
Re: drum to disc on e body? [Re: a12rag] #2821527
09/16/20 01:11 PM
09/16/20 01:11 PM
GA
roadrunninMark Offline
GA
I used the "Disco-Tech" as mentioned by MoparMike, that was about 4-5 years ago. It keeps getting harder to find the old parts anymore as the junkyards are drying up on old inventory. It might be easier and cheaper to go with an existing kit.
Re: drum to disc on e body? [Re: sixpacksteve] #2821537
09/16/20 01:36 PM
09/16/20 01:36 PM
AndyF Offline
AndyF  Offline
If you have a supply of pristine parts cars then go for it. Even in Oregon the supply of parts cars dried up years ago. I used to swing by the local wrecking yard once a month and grab disc brake conversion parts but I stopped doing that 15 years ago when the cars in the yard shifted from RWD to useless FWD garbage. I probably did 50 disc conversions back in the day when I could grab knuckles, rotors and caliper brackets for cheap. I even had a special disc brake conversion tool box that I carried with me that had the right tools to strip the parts I needed.
Re: drum to disc on e body? [Re: AndyF] #2821618
09/16/20 04:32 PM
09/16/20 04:32 PM
a12rag Offline
a12rag  Offline
Probably correct . . . would think getting complete kit would be easiest . . .
https://www.doctordiff.com/front-disc-brake-kit-for-11.75-on-disc-knuckles.html
$600 for complete with all new stuff . . . great deal I figure !
https://www.doctordiff.com/10.95-front-disc-brake-kit.html
$445 for complete with all new stuff (10.95 rotor) . . .
