drum to disc on e body?
#2821431
09/16/20 10:01 AM
09/16/20 10:01 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
ok, What will i need to convert from a-b body to e body, spindles, rotors, calipers etc..?
Hell Hath No Fury Like Mine
Re: drum to disc on e body?
[Re: a12rag]
#2821441
09/16/20 10:20 AM
09/16/20 10:20 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
hoping to to it off parts cars, what parts will work off which car?
[Re: sixpacksteve]
#2821517
09/16/20 12:41 PM
09/16/20 12:41 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
hoping to to it off parts cars, what parts will work off which car? There are many out there that would poo poo it, but go with F, M, J body spindles, rotors, calipers . . . they used to be pretty plentiful, and they do work. I would get the stainless steel braided brake lines (Dr. Diff) . . .if you "can" find" a mid 70's B body, then you could get the caliper adapter that would allow you to go with the 11.75" rotor. Although the smaller rotor still has better stopping than front drum brakes. Anyhow, good luck . . .
[Re: sixpacksteve]
#2821537
09/16/20 01:36 PM
09/16/20 01:36 PM
Posts: 31,041 Oregon
AndyF
hoping to to it off parts cars, what parts will work off which car? If you have a supply of pristine parts cars then go for it. Even in Oregon the supply of parts cars dried up years ago. I used to swing by the local wrecking yard once a month and grab disc brake conversion parts but I stopped doing that 15 years ago when the cars in the yard shifted from RWD to useless FWD garbage. I probably did 50 disc conversions back in the day when I could grab knuckles, rotors and caliper brackets for cheap. I even had a special disc brake conversion tool box that I carried with me that had the right tools to strip the parts I needed.
[Re: AndyF]
#2821618
09/16/20 04:32 PM
09/16/20 04:32 PM
a12rag
hoping to to it off parts cars, what parts will work off which car? If you have a supply of pristine parts cars then go for it. Even in Oregon the supply of parts cars dried up years ago. I used to swing by the local wrecking yard once a month and grab disc brake conversion parts but I stopped doing that 15 years ago when the cars in the yard shifted from RWD to useless FWD garbage. I probably did 50 disc conversions back in the day when I could grab knuckles, rotors and caliper brackets for cheap. I even had a special disc brake conversion tool box that I carried with me that had the right tools to strip the parts I needed. Probably correct . . . would think getting complete kit would be easiest . . . https://www.doctordiff.com/front-disc-brake-kit-for-11.75-on-disc-knuckles.html$600 for complete with all new stuff . . . great deal I figure ! https://www.doctordiff.com/10.95-front-disc-brake-kit.html$445 for complete with all new stuff (10.95 rotor) . . .
