Re: A727TF kickdown adjustment
[Re: moparjack44]
#2823633
09/22/20 02:07 PM
09/22/20 02:07 PM
Posts: 26,037 Rio Linda, CA
John_Kunkel
Rio Linda, CA
do you have a link or picture for the offenhauser linkage ? No, sorry. I found it on the Hemi Hot Heads site. I believe that linkage merely hooks dual carbs together, doesn't connect to the trans.
[Re: John_Kunkel]
#2823948
09/23/20 09:32 AM
09/23/20 09:32 AM
Posts: 211 Halifax, VA.
moparjack44
Halifax, VA.
do you have a link or picture for the offenhauser linkage ? No, sorry. I found it on the Hemi Hot Heads site. I believe that linkage merely hooks dual carbs together, doesn't connect to the trans. Yes, I think you are right. I have ordered the kickdown kit from Bouchillion. Be glad when it gets here. Will let ya know how it works. Thanks Everyone, you always come thru, Jack
K.I.S.S.
[Re: moparjack44]
#2824124
09/23/20 02:21 PM
09/23/20 02:21 PM
Posts: 19,687 north of coder
moparx
thanks for the linkage replies fellows. is the linkage one to one [both carbs opening the same at once] or progressive ? if progressive, will that affect the bouchillion hookup from how they have it designed for a single carb ? in other words, will any brackets or hardware in the kit need to be modified ?
[Re: moparx]
#2824175
09/23/20 03:46 PM
09/23/20 03:46 PM
John_Kunkel
Rio Linda, CA
Offenhauser offers both direct and progressive kits. I'm sure some fabrication will be required to make them work with the Bouchillon cable setup.
[Re: John_Kunkel]
#2828844
10/05/20 10:29 AM
10/05/20 10:29 AM
moparjack44
Halifax, VA.
do you have a link or picture for the offenhauser linkage ? No, sorry. I found it on the Hemi Hot Heads site. I believe that linkage merely hooks dual carbs together, doesn't connect to the trans. Got my kit from Bochillon. Looks great, but have nothing positive to say about the instructions. Shows each step for the Holley, then the OEM, then aftermarket Edelbrock (thats me) then the Demon, then goes to step 2 for all 4 carbs, each then step 3, 4, , etc, etc, etc,. Can someone put together for me each simple step for my set up? The Holley, OEM, Demon, not applicable for me, and confuses me. Jack
K.I.S.S.
[Re: John_Kunkel]
#2828859
10/05/20 10:52 AM
10/05/20 10:52 AM
Posts: 250 Iceland
BadMoonRacer
Iceland
Anyone else with "simple" solutions (I ain't no mechanic), will be greatly appreciated. You have all the info you need, the problem is the Lokar..........it's poorly designed AKA junk. I second that opinion. Lost a very important race due to poor quality of my Lokar. Will never use it again, Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
[Re: moparjack44]
#2829699
10/07/20 10:32 AM
10/07/20 10:32 AM
moparjack44
Halifax, VA.
do you have a link or picture for the offenhauser linkage ? No, sorry. I found it on the Hemi Hot Heads site. I believe that linkage merely hooks dual carbs together, doesn't connect to the trans. Got my kit from Bochillon. Looks great, but have nothing positive to say about the instructions. Shows each step for the Holley, then the OEM, then aftermarket Edelbrock (thats me) then the Demon, then goes to step 2 for all 4 carbs, each then step 3, 4, , etc, etc, etc,. Can someone put together for me each simple step for my set up? The Holley, OEM, Demon, not applicable for me, and confuses me. Jack OK. I'm diving in the deep end on my own, beginning Monday morning (car show this week-end). Mean while If you think of short cuts or what to be aware of, please let me know, any help greately appreciated. Jack
K.I.S.S.
[Re: BDW]
#2829741
10/07/20 11:32 AM
10/07/20 11:32 AM
Posts: 4,769 Moved to N.E. Tennessee
GomangoCuda
I am a little confused. How can a kickdown cable kit be an exact copy of the factory system which does not use a cable?
[Re: GomangoCuda]
#2829801
10/07/20 01:08 PM
10/07/20 01:08 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
It is a copy of the 90' Dodge Ram/Dakota Magnum engine kickdown setup. Go to the junkyard and get this setup for practically nothing and make a carb mount for it.
The only Carbs I care about are under the hood!
[Re: moparx]
#2830113
10/07/20 08:09 PM
10/07/20 08:09 PM
Azzkikrcuda
North Dakota
The aluminum throttle bracket everyone sells works good for this setup.
[Re: A727Tflite]
#2830247
10/08/20 09:43 AM
10/08/20 09:43 AM
moparjack44
Halifax, VA.
You had the talent to mate an old engine to a newer trans, just do what somewhat mentioned - calculate total travel at the carb then modify the throttle pressure lever to get you what you need at the trans.
No, you give me way too much credit. Hot Heads has adapter to hook small block 727TF to early Hemi's. It was pretty straight forward and I had help from a "real" mechanic.
K.I.S.S.
[Re: Azzkikrcuda]
#2830250
10/08/20 09:51 AM
10/08/20 09:51 AM
moparjack44
Halifax, VA.
The aluminum throttle bracket everyone sells works good for this setup. Very neat, my application is Edelbrock, 2-4s? You say everyone, you mean Summitt, Jegs, etc. or specialty vendors? Jack
K.I.S.S.
[Re: moparjack44]
#2830256
10/08/20 09:57 AM
10/08/20 09:57 AM
moparjack44
Halifax, VA.
Another kink in the "hose". With car on lift, wife in the car, I had her floor it (not running), the kickdown lever on the trans came forward a little, not backward at all? Would it have anything to do with fact car was cold and tranny in Park? After thinking about it, I think that could have been the problem..
Jack
K.I.S.S.
[Re: moparjack44]
#2830434
10/08/20 03:24 PM
10/08/20 03:24 PM
John_Kunkel
Rio Linda, CA
The gear it's has no bearing on the TP linkage operation. If flooring the throttle moves the trans lever forward, the linkage is hooked up to the wrong side of the throttle lever. Time for some pics.
