8 3/4 Center section question #2819727
09/11/20 04:04 PM
09/11/20 04:04 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I've read posts in the past regarding which 8 3/4 center sections are better and it raised a question. Were the various centers (741, 742, 489) specific to certain years or were there years where any two or even all three could have been installed at the factory? If any two or all three could have been installed in any specific year or model car, was there a determining factor as to which one would have been installed?
Re: 8 3/4 Center section question [Re: 6PAX] #2819735
09/11/20 04:44 PM
09/11/20 04:44 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
741 and 742 came first then the 489 in 1969 (?).
I think the 489 replaced the 742 when it became available.
741 seemed to end up in light cars or low horsepower cars. I see them in 318 station wagons and a-bodies.
Re: 8 3/4 Center section question [Re: 6PAX] #2819740
09/11/20 04:49 PM
09/11/20 04:49 PM
CA
crackedback Offline
crackedback  Offline
CA
the strength/bearing thing is BS. There are design issues with each case/gear set.
The 741 is a very capable piece.
Ring deflection is the biggest problem when HP goes up. Caps breaking and distorting which isn't significantly different from case to case.
It's one of the biggest red herring in the mopar world... JMO
Re: 8 3/4 Center section question [Re: crackedback] #2819746
09/11/20 05:09 PM
09/11/20 05:09 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
It really doesn't matter much either way since there are far fewer gear choices for the 741.
Master, again and still
Re: 8 3/4 Center section question [Re: DaveRS23] #2819750
09/11/20 05:27 PM
09/11/20 05:27 PM
McGregor,Iowa 52157
500ciDuster Online content
500ciDuster  Online Content
McGregor,Iowa 52157
741's and the other small pinion carriers were in max wedge cars
Re: 8 3/4 Center section question [Re: 500ciDuster] #2819780
09/11/20 07:09 PM
09/11/20 07:09 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
1 have a 741 3.91 SG that came out of a '69 340 Dart. I used it in my red car shen I was spraying it. Never broke it.
Re: 8 3/4 Center section question [Re: 6PAX] #2819781
09/11/20 07:10 PM
09/11/20 07:10 PM
All three carriers where installed in all cars using 8 3/4 housing in 1969, the 489 case was another mid year parts change that Mopar factories did for some reason not divulge to us racers and consumers shruggy
Before that mid year change only the 741 and 742 cases where used from around 1961 shruggyscope
Re: 8 3/4 Center section question [Re: Cab_Burge] #2819783
09/11/20 07:13 PM
09/11/20 07:13 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
which is better the clutch type or cone type in the limited slip.
Re: 8 3/4 Center section question [Re: slantzilla] #2819817
09/11/20 08:46 PM
09/11/20 08:46 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I had a '69 Dart Swinger factory 340 car that also came with a 741 sure grip. The clutch sure grips are the ones to look for.
Re: 8 3/4 Center section question [Re: AARCONV] #2819854
09/11/20 11:37 PM
09/11/20 11:37 PM
Dana Corp. clutch type due to them being rebuildable up
Re: 8 3/4 Center section question [Re: Cab_Burge] #2819858
09/11/20 11:59 PM
09/11/20 11:59 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
CAB it’s no mystery why they dumped the 742 and went to the 489. The crush sleeve saves assembly time.
The 741 and 489 take the same pinion seal. The 742 pinion seal has a much bigger outer diameter and that’s because the pinion bearings are larger diameter.
Re: 8 3/4 Center section question [Re: NANKET] #2819915
09/12/20 09:40 AM
09/12/20 09:40 AM
iagree
I've seen one 489 pinion shaft twisted in two pieces by a off road guy who had replaced the 9 1/4 rear end in his 4x4 Ramcharger with the 8 3/4 out of a late model C body and had the pinion angle pointed up past the alignment with the drive shaft down
I've broken and cracked the teeth on all three 8 3/4 ring gears, not so on a Dana 60 yet luck whistling
Re: 8 3/4 Center section question [Re: 500ciDuster] #2819951
09/12/20 12:04 PM
09/12/20 12:04 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Uh-uh. MW cars got the 1 3/4" pinion either 742 or 985 housings.
Re: 8 3/4 Center section question [Re: John_Kunkel] #2819975
09/12/20 01:02 PM
09/12/20 01:02 PM
Every 8 3/4" rear failure I've seen has been either teeth broken off the ring gear (which damages the pinion teeth), or the axles twisting at the splines. I've never seen a pinion shaft twist in half on any of the 741, 742 or 489 cases.
Re: 8 3/4 Center section question [Re: GODSCOUNTRY340] #2819992
09/12/20 02:15 PM
09/12/20 02:15 PM
Rio Linda, CA
Rio Linda, CA
It's rare but it can happen
