Re: 8 3/4 Center section question
[Re: crackedback]
#2819746
09/11/20 05:09 PM
09/11/20 05:09 PM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
It really doesn't matter much either way since there are far fewer gear choices for the 741.
Master, again and still
[Re: 500ciDuster]
#2819780
09/11/20 07:09 PM
09/11/20 07:09 PM
Posts: 20,177 Park Forest, IL
slantzilla
Park Forest, IL
1 have a 741 3.91 SG that came out of a '69 340 Dart. I used it in my red car shen I was spraying it. Never broke it.
[Re: 6PAX]
#2819781
09/11/20 07:10 PM
09/11/20 07:10 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
All three carriers where installed in all cars using 8 3/4 housing in 1969, the 489 case was another mid year parts change that Mopar factories did for some reason not divulge to us racers and consumers Before that mid year change only the 741 and 742 cases where used from around 1961
[Re: slantzilla]
#2819817
09/11/20 08:46 PM
09/11/20 08:46 PM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
1 have a 741 3.91 SG that came out of a '69 340 Dart. I used it in my red car shen I was spraying it. Never broke it. I had a '69 Dart Swinger factory 340 car that also came with a 741 sure grip. The clutch sure grips are the ones to look for.
[Re: 500ciDuster]
#2819951
09/12/20 12:04 PM
09/12/20 12:04 PM
Posts: 25,790 Rio Linda, CA
John_Kunkel
Rio Linda, CA
741's and the other small pinion carriers were in max wedge cars Uh-uh. MW cars got the 1 3/4" pinion either 742 or 985 housings.
[Re: John_Kunkel]
#2819975
09/12/20 01:02 PM
09/12/20 01:02 PM
GODSCOUNTRY340
Every 8 3/4" rear failure I've seen has been either teeth broken off the ring gear (which damages the pinion teeth), or the axles twisting at the splines. I've never seen a pinion shaft twist in half on any of the 741, 742 or 489 cases.
