LSM on engine valve spring compressor #2819327
09/10/20 01:52 PM
09/10/20 01:52 PM
MN
JERICOGTX Offline OP
MN
Has anyone used a On engine valve spring compressor from LSM? I'd like to see one used on a stock type rocker setup.
Thanks.
69 GTX 68 Road Runner
Re: LSM on engine valve spring compressor [Re: JERICOGTX] #2819336
09/10/20 02:22 PM
09/10/20 02:22 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I used the SC-100 on a 340 this past Winter. Once I got the mounting plate figured out, this tool was a breeze to use! I will be using it again in a few weeks. I like that once you remove the locks, you can slide the tool away to allow your hands some room to swap out springs/shims as needed. Then just slide it back on center.
Re: LSM on engine valve spring compressor [Re: JERICOGTX] #2819339
09/10/20 02:26 PM
09/10/20 02:26 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I have one that I use on my -1 heads as well as a different base so it can be used on 572-13 heads. Have a set for the SR-20’s on my dragster motor. They are the best, a lot of times you just swap out the base and use same compressor part. They are kinda spendy, but after using them, you will be glad. I’ve even used them with heads on the bench when they are big springs. I have an old aluminum stock style head I could mock it up on, but they are very simple to use. Let me know, I can send you pictures. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: LSM on engine valve spring compressor [Re: BANDIT] #2819340
09/10/20 02:29 PM
09/10/20 02:29 PM
montana
BANDIT Offline
BANDIT  Offline
montana
The big block setup isn’t near that complicated, have never used one on a small block. Jim.
4600 DA
Re: LSM on engine valve spring compressor [Re: BANDIT] #2819347
09/10/20 02:50 PM
09/10/20 02:50 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""The big block setup isn’t near that complicated""
I started with a smaller plate (depth wise), but I ran out of adjustment with the 2 screws up top. So I moved the tool farther away from the springs (as shown) and it worked out much better. I then added the bolts to the bottom of the plate (resting on the head) just to give the plate some more support and not all of the load is on the two rocker shaft bolts. Once this was worked out, the spring swap was quick and easy.
Re: LSM on engine valve spring compressor [Re: BANDIT] #2819348
09/10/20 02:51 PM
09/10/20 02:51 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Money well spent.
No regrets buying the one I have.
Makes spring removal in the car a breeze.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: LSM on engine valve spring compressor [Re: Wookie316] #2819529
09/10/20 11:07 PM
09/10/20 11:07 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If you want to try before you buy send me a PM and you can use mine and see how nice they work
Gus beer
64 Plymouth Savoy
Dana 60
Re: LSM on engine valve spring compressor [Re: JERICOGTX] #2819562
09/11/20 01:32 AM
09/11/20 01:32 AM
I bought and have used the Mopar brand BB and SB tool they sell on the motor, they both worked good up
I ended up selling the SB kit several years back to not building any SB up here in 6 yrs shruggy
Re: LSM on engine valve spring compressor [Re: Cab_Burge] #2819605
09/11/20 08:52 AM
09/11/20 08:52 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
They do NOT make one for the 2nd gen hemi. It would be easy to yet they choose not to......................... spank
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: LSM on engine valve spring compressor [Re: hemi-itis] #2819620
09/11/20 10:27 AM
09/11/20 10:27 AM
MN
MN
Thanks everyone. It's been on my radar for a while, and I have other LSM stuff that I'm very happy with. Just wanted to make sure it worked on stock type rocker shaft setups, and not just ones with milled off stands. I'll put it on my wish list.
Re: LSM on engine valve spring compressor [Re: JERICOGTX] #2819638
09/11/20 11:42 AM
09/11/20 11:42 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have them for all our stuff. Common shaft and paired rockers and the predator
