LSM on engine valve spring compressor
#2819327
09/10/20 01:52 PM
09/10/20 01:52 PM
Posts: 10,022 MN
JERICOGTX
MN
Has anyone used a On engine valve spring compressor from LSM? I'd like to see one used on a stock type rocker setup.
Thanks.
69 GTX
68 Road Runner
Re: LSM on engine valve spring compressor
[Re: JERICOGTX]
#2819336
09/10/20 02:22 PM
09/10/20 02:22 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I used the SC-100 on a 340 this past Winter. Once I got the mounting plate figured out, this tool was a breeze to use! I will be using it again in a few weeks. I like that once you remove the locks, you can slide the tool away to allow your hands some room to swap out springs/shims as needed. Then just slide it back on center.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: JERICOGTX]
#2819339
09/10/20 02:26 PM
09/10/20 02:26 PM
Posts: 422 montana
BANDIT
montana
I have one that I use on my -1 heads as well as a different base so it can be used on 572-13 heads. Have a set for the SR-20’s on my dragster motor. They are the best, a lot of times you just swap out the base and use same compressor part. They are kinda spendy, but after using them, you will be glad. I’ve even used them with heads on the bench when they are big springs. I have an old aluminum stock style head I could mock it up on, but they are very simple to use. Let me know, I can send you pictures. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: BANDIT]
#2819340
09/10/20 02:29 PM
09/10/20 02:29 PM
Posts: 422 montana
BANDIT
montana
The big block setup isn’t near that complicated, have never used one on a small block. Jim.
[Re: BANDIT]
#2819347
09/10/20 02:50 PM
09/10/20 02:50 PM
YO7_A66
Indiana
""The big block setup isn’t near that complicated""
I started with a smaller plate (depth wise), but I ran out of adjustment with the 2 screws up top. So I moved the tool farther away from the springs (as shown) and it worked out much better. I then added the bolts to the bottom of the plate (resting on the head) just to give the plate some more support and not all of the load is on the two rocker shaft bolts. Once this was worked out, the spring swap was quick and easy.
[Re: BANDIT]
#2819348
09/10/20 02:51 PM
09/10/20 02:51 PM
Posts: 326 Alberta
Wookie316
Alberta
Money well spent. No regrets buying the one I have. Makes spring removal in the car a breeze.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2819529
09/10/20 11:07 PM
09/10/20 11:07 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
If you want to try before you buy send me a PM and you can use mine and see how nice they work Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: hemi-itis]
#2819620
09/11/20 10:27 AM
09/11/20 10:27 AM
Posts: 10,022 MN
JERICOGTX
MN
Thanks everyone. It's been on my radar for a while, and I have other LSM stuff that I'm very happy with. Just wanted to make sure it worked on stock type rocker shaft setups, and not just ones with milled off stands. I'll put it on my wish list.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2819638
09/11/20 11:42 AM
09/11/20 11:42 AM
Posts: 19,366 Las Vegas
Al_Alguire
Las Vegas
We have them for all our stuff. Common shaft and paired rockers and the predator
