Cuda Vert Seat Belt Bolts #2818600
09/08/20 03:23 PM
09/08/20 03:23 PM
White Plains, NY
VCODE Online boogie OP
VCODE  Online Boogie OP
White Plains, NY
Does a Cuda vert use the same seat belt bolts as a hardtop. I know there is no should harness bolts. Also the inner seat belt has only one strap, so does that a different bolt also. Or are all the bolts the same less the 2 should harness bolts
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Cuda Vert Seat Belt Bolts [Re: VCODE] #2818892
09/09/20 10:42 AM
09/09/20 10:42 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
All the bolts are the same for both hardtop and convertible.As mentioned the roof belts and bolts do not exist on a convertible, but all other bolts are identical for either body style.
Re: Cuda Vert Seat Belt Bolts [Re: m46rat] #2818963
09/09/20 01:25 PM
09/09/20 01:25 PM
White Plains, NY
White Plains, NY
Dwight, Thanks for clearing it up for me.
Bob
Re: Cuda Vert Seat Belt Bolts [Re: VCODE] #2819035
09/09/20 05:45 PM
09/09/20 05:45 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
[s][/s]
Bob
C10 retractors
C-11 rear outer belt. (Also for shoulder belts)
C-12 Front and rear center
Abe Lincoln
Re: Cuda Vert Seat Belt Bolts [Re: dart4forte] #2819198
09/10/20 08:37 AM
09/10/20 08:37 AM
m46rat Offline
m46rat  Offline
Originally Posted by dart4forte
[s][/s]
Bob
C10 retractors
To correct the above:
Front retractor("pull") belts, the correct bolts for securing these are stamped or cast C01 and are silver zinc in colour
The roof belts and the four rear belts all use bolts that are stamped or cast C11 and are black zinc in colour
The front two belts that are secured to the drive shaft tunnel area are always stamped or cast C12 and are gold zinc in colour
Re: Cuda Vert Seat Belt Bolts [Re: m46rat] #2819259
09/10/20 11:36 AM
09/10/20 11:36 AM
White Plains, NY
White Plains, NY
[s][/s]
Bob
C10 retractors
I have the two C01 silver ones that have threads all the way up with no shoulder, also used with a thin flat washer.
Re: Cuda Vert Seat Belt Bolts [Re: VCODE] #2819301
09/10/20 12:53 PM
09/10/20 12:53 PM
m46rat Offline
m46rat  Offline
One washer on top of the retractor housing and in between the C01 bolt. Correct.
Re: Cuda Vert Seat Belt Bolts [Re: m46rat] #2819344
09/10/20 02:45 PM
09/10/20 02:45 PM
White Plains, NY
White Plains, NY
That's what I do
Bob
