Re: Clutch 4 Speed Experts
[Re: Droop69]
#2818905
09/09/20 11:14 AM
09/09/20 11:14 AM
Posts: 4,457 Washington
madscientist
Washington
These are the part numbers of my clutch and pressure plate. I sent an E-mail to Brewers but have not heard back yet. That’s what happens when the cover flexes. What disc are you running? If it’s a rag disc you need NO MORE than 2400 pounds of plate load. If it’s some dual friction thing, get rid of it and get a rag disc. If you have to remove springs to get the plate load down to 2400 do it. If run that cover with 6 springs. You’ll probably need to go down to 9 springs to get there.
[Re: Droop69]
#2818936
09/09/20 12:31 PM
09/09/20 12:31 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
The only time a clutch wears or develops enough heat to blue the steel/iron surfaces is when it is slipping. Not knowing how you drive/use a clutch is an issue. I've seen guys who have been around cars for years and know how to build them use the clutch to "hill hold" a car. Or they slip it well past when it could have been solidly engaged while taking off.
I'm not commenting on how you used it here. Just saying.
I would call McLeod, get a Return Authorization, and have them refresh the cover. Tell them what you are running and follow their recommendation. There's no way a 2400lbs cover would last in any of the 440 cars I build over the years. A local shop here build me a 3400lbs cover that never warped. I still have a fresh 3400 lbs cover in my basement from back in the day. It would break the release arms on occasion though.
You could also scuff the glaze off the cover and put a fresh disc in, but that is a pretty wimpy clutch except for a stock small block or something to begin with. Then again, some folks never use full power on their rides. I just can't imagine living like that. Life is too short. Then again, speed cost money . How fast do you want to go.
I am currently using a Street Twin from McLeod. It's the only clutch I've ever used that consistently works correctly and never slips once engaged. Best clutch ever
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2818954
09/09/20 01:02 PM
09/09/20 01:02 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
<<<snip>>>>
I am currently using a Street Twin from McLeod. It's the only clutch I've ever used that consistently works correctly and never slips once engaged. Best clutch ever I had failures similar to that in two clutches behind a decently built 440. I ended up going with a street twin and haven't looked back since. I have a 383 for my next project and was thinking of doing a 432 stroker kit. Not sure if the street twin would be overkill or not. But man I love that clutch.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: jbc426]
#2818979
09/09/20 02:07 PM
09/09/20 02:07 PM
Posts: 962 MN
Droop69
MN
It is a pretty bone stock 383 small cam, the original motor for the car. I went with what Brewers suggested, and adjusted it according to Mcleods installation instructions. There is very little use on this set up maybe 50 miles. Maybe I adjusted the clutch wrong...
I do remember when we were loading it on the trailer to bring to the front end shop for alignment, there was some clutch smell. Car was running like crap and hard to get up the ramps, that might have done it.
